One more comment, I don't think setting it to 66 on automatic_AC necessarily uses any more electricity than say setting it to 70 and turning the fan way up. The way their AC works is basically about 4 temp settings and then the fan settings as a separate entity. The following are pretty true regardless of fan speed, but the outside temp plays a factor, so just assume these during warm or hot weather:
a. AC is on, inside circulation (re circulation of inside air). That's their cold mode.
b. AC is on, outside circulation, that's their cool but not cold mode (problem here is humidity where I live).
c. AC is on, heatpump is on low, outside circulation might be on depending... this is the lukewarm mode.
d. AC is on, heatpump is on max... this is hot mode. Uses the most electricity, not including fan considerations. This is what causes the battery to drain like mad during the winter.
You can have any fan speed during any of these modes to either increase or decrease the effect.
For Manual AC mode, what we'd all want is...
1. Recirculation On/Off toggle, and do NOT change it when in manual mode, unless I press the button to change it.
2. AC On/Off toggle.
3. Heatpump - low/hi toggle.
