same.I look forward to seeing some real reviews and general user experiences.
Mine just came yesterday - will install tomorrow.
Bought it here. Prime shipping and easy returns with Amazon...same camera.
https://www.amazon.com/dp/B01FTYU70Y/ref=olp_product_details?_encoding=UTF8&me=
I've got one of these from Amazon as well. The install is a little finicky in terms of the plastic housing snapping into place just right, but it wasn't too bad. Power was very easy to tap. They have a Youtube video, which made far more sense than the Engrish instructions.
The default wifi password is in the instruction manual, which may be easy to miss given the number of other goodies (phone holders, etc) that they stuffed in the box.
Also speaking of that, you can telnet into the dash cam on its wifi network -- it's running Linux on some sort of armv6 processor with hostapd providing wifi, so if you're a Linux junkie the possibilities are endless (e.g. getting it to connect to wifi as a client, auto-upload video, you name it). But if you're not a Linux junkie, the takeaway is change the default wifi password because the last thing you want in your car is an easily rootable device with wifi, a camera, a microphone and GPS!
OK - just installed in in 20 min - seems to work just fine.
How do I change the wifi password as mentioned above??
Is the power always on or only on when the car is turned on?
Only when the car is turned on. It taps the mirror dimmer's power, which appears to be switched with the ignition.
Are you sure?This should be always on. It is the same connector as the blackvue taps into.
Bet it won't work, or at least the housing will have to be different to attach to the mirror. Doesn't Hdw2 have 3 cameras and a wider housing than some of our ancient AP with Hdw1 do?I'd be curious to know if this will work on the new AP2 equipped vehicles?
no, for Blackvue to stay always on it will need to tap into spare connector under the microphone cover on the roof.This should be always on. It is the same connector as the blackvue taps into.
Ok thanks. I thought it was the same connector. In that case this camera is a no go for me!no, for Blackvue to stay always on it will need to tap into spare connector under the microphone cover on the roof.
