I'm sure it's still possible. A bad connection at the plug can cause heat build up. Any adapter has that risk to a degree over a fixed and closed connection/cable. But how many times does it happen these days with the new replaced adapters and how many times of those cases was it user error?
Point is that's not the reason that switched to 32 Amp on the new UMC, It is not a recall or safety issue. The original post that suggested it would be a safety issue with the old UMC turned out to be just a misunderstanding. I'm not saying the old UMC is perfect. Any time you introduce a connector/adapter to a high power system you adding a possible problem. That's why the wall connector is so much better. It's all a fixed connection.
