sorka
Assuming you mean without disabling connectivity completely, I just had a thought.
You can try leaving your car "ON" all the time. If you press the brake pedal after getting out of the seat, the car will go to "ON" mode and not shut off when you close the door. It'd be a bit wasteful with excessive vampire drain, and you'd have to make sure the car locks every time or someone could sit and drive away. I doubt the car can upgrade when "ON."
Oops - nor can you charge though... Maybe if you charge during the day and leave it on at night? Aren't all these forced updates happening over night?
It's also not as simple as connecting to a dummy AP that has no real internet access. As soon as you cut off internet access of the middle man, the tesla goes back onto LTE.
What I need is some sort of firewall that allows traffic in but allows me to prevent file downloads that exceed some largish size.
Can anyone suggest any such wifi router? Of course that will only help if I'm at home. Parked at work or anywhere else, I'd need a different solution like a mobile hotspot that I'm always connected to that can prevent large file downloads.
I have a verizon mobile hotspot. I guess I should check and see if it has any such controls.
