We currently have a single PW2 and gateway 2 installed, which is mounted on a wooden/unistrut structure.
Obviously we can’t stack on this configuration, as you must floor mount stacks. However we also need to keep the PW2 a couple of inches off the ground to make sure heavy rain wouldn’t cause problems.
I know you can mount on a concrete slab, with the lateral support cast in, but we don’t have space to cast the minimum dimensions.
Is is possible and suitable to cast a slab a bit bigger than a 2PW stack, place them on this and use the existing wooden wall to provide the lateral support?
We sadly don’t have space to not mount as a stack, so the other option would be to just not do it.
Thanks in advance.
Thanks in advance.
