What makes you think that? To my knowledge all the major streaming services use 44kHz sampling rate, as do music files purchased e.g. from iTunes or Amazon or ripped from CD (which also uses 44kHz). Phones will not resample that to 48kHz as there would be no benefit in doing so. There might be a tiny benefit if you have music files with 48kHz sampling rate from somewhere.v10 added 48khz sampling via BT. That helps a ton.
Is there a "switch" that you need to click on in V10 to enable 48 kHz sampling that we're not aware of? Or is it done automatically?v10 added 48khz sampling via BT. That helps a ton.
This is not accurate. AptX supports a range of sampling rates, including 44kHz. But it does not matter in this case since Tesla does not support AptX anyway (it supports SBC and AAC over BT).Because the aptX codec is native at 48kHz. No matter the source sample, it’s going to be transcoded using the codec. Better sample rate - native sample rate - will help a ton. It’s coming - Apple is pushing 48kHz big time for source format, so we’ll start seeing it everywhere soon ...
If you actually have native 48kHz music sources, there might be a *tiny* difference since you no longer have to resample (although I doubt very much that you could tell the difference unless you're a bat ). But the vast majority of consumer music formats use 44kHz today.sure; of course it supports 44.1 like everything else in the world. But 48 is now also native and that’s a good thing. Most digital production is now done at 48 and downsamples to 44.1. And yes - you’re right, I was thinking of AAC and not aptX. My apologies.
Honestly, I don't buy this at all. No matter how good the speaker system, a car is a noisy and acoustically less than optimal environment, and whatever small amount of difference the resampling might make will be orders of magnitude lower. Frankly, the whole idea of audiophile audio formats in a car sounds a bit ridiculous to me. If you want to enjoy every nuance, sit down with high-quality headphones in a quiet room.I don’t know nearly enough about Tesla’s audio componentry but any chance we have to avoid noise injection, I’m all for it.
Should reduce some of the background noise - and on a system as good as the Model 3’s, it’ll make a difference.
Only for iOS
Indeed!
IMHO, Pandora has both of these streaming apps beaten soundly. ...My only caveat to Pandora is that I need to connect to it via bluetooth with my iPhone and, as such, the sound quality is not up there with those that use streaming directly to the Tesla.
The format is one thing, but you must also have the right system in the car. The Tesla system (even the Premium) cannot deliver that. If you're ever down in Orange County, look me up and I will demonstrate what I'm talking about.Frankly, the whole idea of audiophile audio formats in a car sounds a bit ridiculous to me. If you want to enjoy every nuance, sit down with high-quality headphones in a quiet room.
I don't listen to any of the streaming music services simply because they simply can't provide quality sound.
No matter how good your system is, a car will always be a compromised listening environment. I know that some people are having fun with upgraded audio systems, big bass etc., but don't pretend it's "audiophile".The format is one thing, but you must also have the right system in the car. The Tesla system (even the Premium) cannot deliver that. If you're ever down in Orange County, look me up and I will demonstrate what I'm talking about.
It's audiophile, whether you chose to believe it or not. You're forming an uneducated opinion unless you've heard it.No matter how good your system is, a car will always be a compromised listening environment. I know that some people are having fun with upgraded audio systems, big bass etc., but don't pretend it's "audiophile".
Well, I guess we have a different definition of "audiophile". At home I have a system that costs more than some cars, so I think I have a pretty good idea what good sound is.It's audiophile, whether you chose to believe it or not. You're forming an uneducated opinion unless you've heard it.
Is it as good as a home listening environment? Of course not. But
- It is still audiophile quality
- I do a lot of listening while not driving.
Where do you see this or confirmed? The release notes state that album art integration over BT is only iOS. Nothing about 48 kHz being iOS only. If youre on android, enable developer setting, then change the BT Audio codec to AAC and BT sample rate to 48 kHz. However, like others have mentioned, you likely wont even notice a difference since most music is in 44 kHz
If you've driven nothing but Honda Civics in your life, you don't know what it's like to drive a Porsche. So yes, I'd say that is true.Does someone buying a more expensive car inherently mean they know more about cars than the next guy?
