stopcrazypp
So it looks like the sea had nothing directly to do with it. Looks like landing was perfect, but the leg gave in.
After watching the instagram movie it appears the upper leg strut that extends to deploy the leg retracted as the Falcon tipped. Was this telescoping tube the failure point?
So close. Reminds me of the Delta Clipper crash.
Well, I'm still trying to decipher what the words "lockout collet didn't latch" can mean:
* I know what a collet is on a machine tool: a friction-based collar that, through its outer threads, squeezes tight whatever shaft, etc., is inside the collar when a female threaded agent bears down on those outer threads.
* I would not use the word "latch" to describe the above action; so either there is some other function or Mr Musk was at a loss for another word during a tweet.
* "Lockout": can this be his way of describing the orientation of the landing leg when fully extended? If not, then I'm still confused.
Well, it did land softly, but fell over because of one of its legs didn't lock properly.Well, Mr Musk and his approach toward the meaning of times and dates may not be the only example of, ummm, "differently measured".
Here is Bloomberg on the Falcon 9 landing, verbatim:
SpaceX later tweeted that the booster “landed softly” within 1.3 meters (8.3 feet) of the ship’s center.
Yes. Based on the video of the landing that SpaceX released, the stage clearly landed right on target and very "softly", but after the successful touchdown one of the 4 legs slowly collapsed causing the stage to fall over.SpaceX later tweeted that the booster “landed softly” within 1.3 meters (8.3 feet) of the ship’s center.
Thanks for your post, very good point. This failure mode would likely have occurred if the stage landing attempt had been on land. Watching the video of the landing I could not see any motion of the drone ship deck compared to the horizon, so it appears that at the time of landing the ship was reasonably stable.What this means is, they have essentially nailed ocean based platform landing.
Good thing this was not RTLS, as this crash would have happened even in land.
<-----Folks, that WAS my point......Btw, Not sure if Bloomberg is accurate, since 1.3 meters = 4.27 feet not 8.3 ft. which equals 2.53 meters.
