Schroth BMW E90 - where does rear anchor bolt to?
Hi Guys,
I have the front anchor installed but not sure exactly where to put the rear anchor. I removed the rear seat and I do see a bracing with bolt to put it
but it would require bending the anchor somewhat.
Appreciate assistance on where to properly bolt it to.
I've attached a picture of the two points that I see that I could bolt to. Point A seems like the one but it would require me to bend the anchor bracket quite a bit.
Thanks,
Steve
Thanks Steve.
You're right looks like I was totally wrong, the anchor ties to the actual seat belt bolt at the bottom. BTW some things I discovered:
-you don't really have to remove the entire rear seat
-fold down the rear seat backing partially
-you have to remove the side bolstering (towards the door) which is kind of a pain (without breaking the big white plastic retaining clip - which Tesla
says has to be replaced)
I've attached some pics
Thanks Steve.
Looks good. I don't remember having to remove the side trim. I think you just need a ratcheting wrench to get under there.
And for anyone viewing this thread wanting to get the Quickfit E90 Harness, id recommends the Non-Pro version if using with the OEM seat. The pro version brings the shoulder straps closer together at your waist resulting in the straps rubbing against your neck. The Non-pro is further apart and does not rub my neck.
Correct the Pro version straps are closer together however note that the reason for this is that it is Hans compatible whereas the regular Quick fit is not.
