Hello! New owner here and just had the wall charger installed. I believe I have an understanding of the options regarding scheduled charging? My off peak hours seem to be 9p-1p. I got scheduled charging set currently to 12a. In the morning I manually precondition the car about 30-45min before I plan on leaving as it's 20F right now. I noticed that on my app, it was showing "start charging at 9pm" and the cable was blue. Upon leaving, I saw that my battery was down 3% from my charge limit (69%). I just wanted to confirm if this is working as intended as I read in the manual, if you set Scheduled Charging, it will only charge up to 6 hours and then will reset/start charging at set time again? Did this occur because my preconditioning time fell just outside the 6hr window or should it still be pulling from the wall connector as it still plugged in? I don't mind moving my schedule time to like 1-2am if so as ideally I want to leave with a full battery to start the day.
Also if this is the case and say I have a trip planned, if increasing the charge limit makes it so it won't be fully charged in the 6hr window, it would be best to use the Scheduled departure time/off peak option (to get majority charge during off peak)?
Thanks in advance!
Thanks in advance!
