We have had our model X since April of this year. We have mostly been charging to 90% or less. Today I went to charge to 100% for our road trip and noticed we lost 9 miles off the estimated range of 295. Is this normal.?
I'm not sure where you got your info. How much is "a few kW lower"??? What I read was that the charging was significantly lower and it was *always* imposed at Superchargers once the owner exceeded the limit.No, you can’t adjust the supercharging rate. And it’s not relevant if you don’t care that it charges that fast, the point is to get you on your way quickly to make room for the others needing to supercharge. Reducing the peak power after hundreds of supercharging sessions isn’t a concern—the peak power may be a few kW lower which wouldn’t even happen unless you start with a very low SOC, and even then it would only add a few minutes to a long supercharging session. Only a very small percentage of owners have been affected by this anyway, mostly with 90kWh batteries. It’s just not something that needs to be on the radar of the typical owner.
I don't know for sure, but this is only 15 miles or less than 5%. Doesn't the charge miles vary with temperature? I was told my a service center tech it takes a few weeks, but as the temps drop it tracks your history and reads a more realistic number going into the winter.I just picked up my CPO 2016 MX 90D last week. I did a full charge last night and the range I got was 242 miles. According to Tesla the max range is 257. Is this normal to be that off for a 2016 MX?
If you use Superchargers at full rate too often they will cut back on your charging rate.
