Not true. Germany's building coal plants as a result of closing nuclear plants is a myth put out by global warming deniers to "prove" that green energy sources aren't viable.Except that you forget that Nuclear can be less expensive. I'd argue that it is easier to make nuclear less expensive than to replace all of that with winter usage with wind. Using a horrible cost example makes the argument convincing for sure for the anti-nuclear side.
"As Germany found..." that when they shut nuclear plants they build more coal plants. Despite a huge solar push - largest in the world. Germany has built (ing) more coal generation than their solar generating capacity and wind combined.
Japan is building 41 new coal plants. Not a typo. Why? Because their electricity use is up so much? No.
Now remind me - is burning coal bad? Is it responsible for the most carbon intensive electricity generation? Is it responsible for more deaths per GWH generated? By a factor of 1000 over nuclear?
Wonder why Germany didn't just build more wind and solar? Or Japan?
I'd argue that if Germany can't do enough wind/solar in 2015/16, good luck in the USA. Sure we could build enough wind. We could also stop using electricity. But it isn't happening. And it won't.
The truth is Germany has build some coal power plants, but they were planned and building started well before the nuclear plant closures.
The truth is, since German actually canceled the construction of coal plants since they closed the nuclear power plants.
Germany builds minus six coal plants after nuclear phaseout
