Portland OR - Uberturbines, Wheels, No TPMS
$2000. Local Pickup Only.
Selling Tesla Model Y Uberturbines. 2000mi on tires. No TPMS. There is a mixture of curb rash (whoops - filled in with color match) and some paint chips on the outer rim due to Les Schwab resting one on the other. You can take a look in the pictures.
Went with a set of smaller aftermarket wheels so no longer need these.
21" Tesla Model Y Überturbine Wheel
Size: 21X9.5" Front, 21X10.5" Rear.
Offset: +40 Front, +48 Rear.
PCD: 5X114.3.
Center Bore: 64.1mm.
Weight: 21x9.5" = 38.05 lbs, 21x10.5" = 38.95 lbs.
Lug Nut Spec: 21mm Hex, 14X1.50 Thread.
Lug Nut Torque Spec: 129 lb-ft.
Tires
Front: Pirelli P Zero 255/35-21 XL 98W ($344 per New Tire)
Rear: Pirelli P Zero 275/35-21 XL 103W ($380 per New Tire)
*Local pick up only*
