PhaseWhite
I am sure there is some room for improvements if you really don't care about reliability at all, but Tesla builds road legal cars, not racing cars. So no, they can't just increase power a lot.
@R.S Thank you for chiming in. Could you please take a look at my analysis below and share your thoughts?
Looking at motor specs on wikipedia, the S75 is listed at 285KW Max motor power. And both 75D and 90D are listed at 386KW motor power. I'd assume the 75D and 90D use the same rear motor as S75, so if this is accurate, then the front motor is only capable of 100KW.
Also looking at max power (battery output) S75 is about 280KW (this is close to the max motor)... But in the 90D it's 310KW, so quite a bit shy of potential motor output.
Seems more like the bottleneck right now is current draw from the battery pack. With 310KW, that's ~775A draw at 400V (I know I'm ignoring voltage drop so probably a bit more).
To get to 345KW output on the 90D/100D (0-60 in 3.3 seconds according to Tesla) that would take 862A + more after voltage drop. Considering that P90/100 can pull 1500-1600 amps, that seems to be within the realm of possible.
Also given that the front motor is capable of 100KW and the rear is capable of 286KW, 345KW combined should be possible based on just motor limits. Thus I think 90D and 100D are likely capable of 345KW P85D performance (pre-ludicrous upgrade). This also aligns with the possible slip up of listing the 100D with 3.3 second 0-60 that spawned this thread.
Tesla Model S - Wikipedia
