The survey just collects the data that's available to the driver. If the differences in apparent battery capacity are due to charging habits, that should show up on the survey because I am collecting data on both of those things. If we find a better measure of battery pack capacity, I'll add that to the survey. If someone has a theory about how to improve the accuracy of the readings, or ways to improve battery longevity, the survey data should be able to help validate (or disprove) that theory.Tom,
Like I stated before(when you first started the report), the Model S battery pack report has a fatal flaw. It only seems to measure how much out of balance some Model S packs are. All it is going to do is create FUD about degradation that is not there.
Model s at 40,000 Miles - Page 3
In which thread? I looked at post 28 in this thread and in the survey thread. Neither seems relevant. You can get a link to a specific post by right-clicking (Windows) or control-clicking (Mac) on the post number.Look at post #28 please.
Post 28 in the thread page I linked.The survey just collects the data that's available to the driver. If the differences in apparent battery capacity are due to charging habits, that should show up on the survey because I am collecting data on both of those things. If we find a better measure of battery pack capacity, I'll add that to the survey. If someone has a theory about how to improve the accuracy of the readings, or ways to improve battery longevity, the survey data should be able to help validate (or disprove) that theory.
If you have thoughts on how the survey could be improved, I'm always open to suggestions. However, this probably isn't the best thread for that discussion. Please PM me or post on the Model S survey thread.
Tom,
They have a depleted loaner fleet. Why couldn't they swap batteries from new loaners as they are delivered with the existing "A" packs that are in the wild. That would make for a loaner fleet that won't be so quickly depleted. Also, that would also result in all owners that ordered cars with the exact same battery specifications getting batteries of comparable performance. Tesla would then retain their Dudley Do-right image.
Bluetinc shared a really nice dataset where he range charged starting from 1 rated mile (8% SOC as gauged from by the REST battery_level parameter) on the 120 KW supercharging thread: Finally 120KW Supercharging! - Page 23
Since he has an "A" battery, and I have a "B" battery (battery SN 6864) I thought I would compare this dataset to the the data I got in July when I was 90 kW limited by the v4.5 software and to the data I got in December when I was 120 kW capable (v5.8). The first plot compares Bluetinc's charging power vs. SOC (state of charge from the REST battery_level- values are integers) in Delaware on Jan. 3rd to the same type of data I gathered at various California 90 kW superchargers between July 19th and July 27th.
The second plot shows bluetinc's SOC vs. time and my SOC vs. time for my most complete 120 kW charging sessions (Tejon Ranch on Dec. 20th).
Since bluetinc started charging at a much lower SOC, I used the portion of his data that overlapped with my data and adjusted his time values accordingly. At least for these two charging sessions, it took bluetinc's 90 kW capable "A" battery about 5 minutes longer to go from 14% SOC (16 rated miles on my car) to 89% than it took for my 120 kW capable "B". It's risky to draw any general conclusions from this since these weren't side-by-side charging sessions and Tesla probably tweaks the supercharger software all the time without telling anyone. But I found the comparisons interesting so I decided to share them. And yes, I'm a total data nerd. But I don't think I'm alone in that respect . . .
Even if it hasn't been implemented yet, Tesla has allegedly stated that it *won't* be implemented for the "A" packs.
In that vein, would you mind glancing at post #1267 and explain why my taper from 90 kW begins at < 40% while both you and bluetinc begin the same taper at 45% (judging from your graph)?
Very inaccurate data doesn't do anyone any good. More inaccurate data is definitely not better, in fact it makes things worse as people freak out for nothing.I'm always a fan of having more data out there rather than less data. I actually find the survey data quite encouraging as some of the cars with the most mileage are reporting very minimal degradation: Plug In America (perhaps because people with the highest mileage have done the most road trips that required deep charge/discharge cycles). If people figure out a robust pack balancing procedure then perhaps the last time an owner balanced their pack can be added to the survey.
A neanderthal sure can!You cannot superimpose % SOC onto rated miles.
Ok, ok. I understand the nuance - but what observable variation does it introduce?
Where does Tesla state this?
That's my point, there is no easy balancing procedure. Your average user is not going to figure any of this out.
My 90% SOC to 100% SOC is 220 -> 250 vs. a newer car that might be 235-265. You'd have to shift the graph 15 rated miles to account for that. If you look at any recent graph and imagine shifting it 15 miles, it makes a HUGE difference.
If that were the case would it not finish FASTER with less potential to store??
