I order it but debating to use it or not. Do I need protector or not. I pretty accurate with iPhone and suchSpigen
If fingerprints bother you and you don't want frequently clean the screen the you will appreciate the protector. The install requires good preparation as any dust settling on the screen while you are installing the protector will have to be removed, else it will form an air bubble. The Spigen screen protector probably has the best installation tool.I order it but debating to use it or not. Do I need protector or not. I pretty accurate with iPhone and such
Exactly why I installed the Spigen matte. I didn't like the glare of the glossy screen during my test drives. I still picks up fingerprints, but not as noticeable.Two issues with the screen; reflections and fingerprints. A matte screen protector will help reduce reflections and make the fingerprints invisible. A screen protector can also protect the screen from damage. All in all, a worthwhile addition.
Check out Abstract Ocean (AO) and Spigen (sold on Amazon).
I got the AO matte screen protector before I received my car. I was a little concerned that I wouldn't like how the matte screen looked, but after installation I've been 100% happy with it. I think it probably isn't really needed, as I don't think the screen is that prone to getting scratched, but if it protects the screen from even one incident it would have been worth it.Is some one not to use screen protector and happy with out it? Got car yesterday, order screen protector and debating to install it. Opinions?
If you have a screen protector on your iPhone, the blur that is introduced as a result of the screen protector won’t bother you much.I order it but debating to use it or not. Do I need protector or not. I pretty accurate with iPhone and such
For those that are using the Spigen Matte protector - did you have to turn up the brightness?
On the contrary, in direct sunlight I can now read the screen when I couldn't before.For those that are using the Spigen Matte protector - did you have to turn up the brightness?
