N2itive rsx-3 lower links won’t snap on
Model S Plaid 2023
Rsx-3 tartan lowering links.
Are these supposed to be that hard to snap onto the balls after removing the factory link?
Is there some technique I am missing?
They just do not want to pop on at either end. I have one of the front ones off and have not tried the rears yet.
Thank you for any suggestions / help you can provide.
Model S Plaid 2023
Have you tried putting a little bit of grease on the ball or in the socket that might help if you have a set of calipers, it might be worth measuring the
ID of the socket compared to the OD of the ball to just double check it’s not way off
