I had issue with steering yoke vibration at 65 MPHand higher.
Multiple tire swaps, wheel set swaps and road force balance attempts didn't address the issue. Also alignment was done without addressing the issue. Finally was told by SC that they suspension engineering team is "working on the fix" and that they will contact me. Vibration persisted and really took away the joy of ownership. I wrote a letter to Tesla corporate and asked them to buy back the car "as they exhausted reasonable number of attempts to fix warrantable issue" ( I opted out of arbitration). After this they took a car for service for 4 weeks. That's what was done:
"Repair Notes: Test drove vehicle and verified vibration present around 75 mph. Performed a balance check of all wheels and verified wheels are all within acceptable balance. Removed customer wheels and installed a known good set. Test drove and verified vibration is still present. Test drove vehicle in the air and verified the front right axle has lateral movement at higher speeds. Requested additional assistance for diagnosis: per diag removed and replaced both front hub assemblies, front right axle and both control arms on the front right side. Assembled vehicle and test drove, verified vibration still present. Removed and inspected the front drive unit: verified no visual issues present with drive unit. Replaced drive unit and performed all required tasks after replacement. Performed an extended test drive and verified vehicle no longer vibrates at speeds about 79-89 MPH. Advise w/ customer: there is still a slight vibration present at higher speeds but this is within normal acceptance for vehicle operation."
Intermittent vibration is still present at 75 mph plus. Frustrating. However it is by 60-75% better - I have Ford Raptor with 37 package and large off road tires - it has less road vibration than my MXP post repair. Don at N2Itive thought it might have to do with angle of front drive unit. Also - I traded my 2022 MXP for 2023 unit (wish I have not done it) and 2022 didn't have this issue. Immediately after delivery of 2023 I found out that Tesla was doing alignment and front tire balancing prior to delivery (this was not disclosed to me prior to delivery) - I find this tactics to be sketchy and it makes me question if they are aware of the issue and still try to sell these defective units to customers.
