Hi all,
A friend of mine has a CTEK Chargestorm Connected 2 installed at home, 32A single phase. Frequently when charging his Model Y LR, the charger will receive a 'SuspendedEV' message, meaning the car is stopping the charge.
Being an electrical mind (We work together in a company of technical engineers), we investigated and found there to be a massive fluctuation of his supply voltage. Now his street is a 1930's build so the DNO's cabling is probably questionable but heres what we have found....
We are logging at 10s intervals the voltage reported by the Carlo Gavazzi MID approved meter in the charger and within the last 15 hours we have seen fluctuations of nearly 30v. And thats without him plugging the car in. Max was 263v and the Min was 230v. However, when he has been charging the car and encountered problems, the car has shown as low as 208v! We will continue to log and see if we can record that but I think theres a problem here....
My suspicion is that either some upstream cabling is badly undersized for the modern demands, or the transformer serving the street is on its way out or undersized. The fact that we have seen voltage as high as nearly 264v so far suggests to me that they may have already tried to compensate for the drop by increasing the transformers output voltage.
Question is, is this a problem for the onboard charger? I have a feeling the low points may well be (~208v) but what about the high (~264v)?
I know these are both way outside of the limits and the DNO needs to sort it out but the more evidence we have the better.
The DNO has been out to him and managed to identify the house is on a 'looped' supply with the neighbour. However they are on 100A fuses and no-one spotted any cabling sizing issues on the incomer. This suggests to me the issues are as I said... upstream cabling or transformer.
Does anyone know the voltage range of the MY onboard charger for the UK market?
Thanks!
Thanks!
