Knightshade
Wider footprint? They're both 235 width tires! Assuming the rubber compounds perform the same, despite the Tesla OE version having a higher treadwear rating, the primary difference would just be the sidewall height/stiffness and every track test I've seen comparing 45 aspect to 35 aspect tires of the same width has put the difference in lap time inside of 2% in the dry. While the advantage still goes to the shorter sidewall in the dry, that can flip in the wet depending on the tire. Point being, the performance differences are small unless driving competitively and the difference in cost and other trades (aero, ride quality, etc.) is significant. If you're driving competitively, then you'll likely be using more track appropriate tires in non-OE wheel and tire sizes anyway.
Yup.... If I'm tracking the car a lot I wouldn't use either I'd be using non-street, likely wider, tires and lightweight wheels... if I'm only going to own ONE set of wheels/tires for 100% of my driving though even if it includes a bit of track, and given the 20s are heavier and will ride rougher off the track, I'd take the 18s with the 4S tires all day every day over the 20s with the 4S tires.
