Liquidmetal101
Same here!You can start one here.
i'd be interested in a tire group buy if that is possible. I'll be using my Aero rims as winter rims.
SOOO expensive to buy extra rims. FWIW, I routinely transfer my summer and winter tires to the same rims - tires are balanced every time (slight wheel vibrations drive me crazy!) Also, less heavy to transport, if you can't find an inexpensive garage to store them.
Do you do the swap/balance yourself? Doing it at a garage has never made financial sense to me, even a decent cash price where I live is $60-70 to swap and balance. x2 and that's lets say $130/year, plus then you are potentially banging up your rims.
I'm still undecided what I'm going to do with my model 3, but on my past 2 cars (2014 volt and 2017 volt) I had steelies on it since the rims were ~$60 each, and I install them on the car myself at home once I have them on rims. Also do the same with my wife's bolt. Not sure if there will be steelies that fit the 3, but that's going to be my preferred route rather than paying $1000 for rims
I know it wont make the car look pretty, but to each his own....unless there is a good deal with the group by mentioned above in which case I may be convinced to join in
Yes, because the red dot (heaviest point) will be in a different location every time. Pros, swapping = balanced tires all year long. Cons, can damage rims if shop is shady.Is it necessary to re-balance the tire every time you swap back and forth between wheel sets?
Tires don't do well stretching on and off rims twice a year...
The tires get stretched twice. When put on, and 6 months later off.It's once a year per tire (twice per year per wheel). And respectfully, I've never had a tire rim fail before the tread wore out. I'm not saying everyone should do this, it's just an economical option that leaves my nice rims on year round, and the tires are always balanced (yes, @Funkmobile, you need to balance every time you put a tire on the rim.)
You're right, @Gen3. Still, this hasn't been an issue for me during the time I've done this. I think as wheel sizes become bigger and sidewalls shorter, this is less stressful on them. Perhaps?
Besides the cost of mounting/dismounting your tires twice per year, each on/off cycle risks damaging the tires or even the wheels. There’s at least a $60 difference in cost at my shop between swapping unmounted tires and exchanging mounted tires, so it only takes a couple of seasonal changes to effectively pay for the wheels.
Tire balancing, inspections, and pressure check
Regardless of which tire service you require, all new, swapped or changeover tires need to be checked for proper balance and tire pressure. In addition, swapped tires should be checked for irregular wear patterns such as inside or outside rubber wear. If there are signs of irregular tread wear, this should be indicated on the repair order along with the recommendation of a four wheel alignment verification.
I guess if you're able to do it yourself and it's not an issue that's fine but I have to have it done in a tire shop and it's not cheap twice a year. I'd way rather put that money towards an extra set of rims.
How to change your tires from summers to winters | The Star
If you want nicer wheels, it takes more than "a couple" of seasonal changes but not that many more.
What's the difference between a tire changeover and swap? | OK Tire
I beg to differ on all accounts. It costs more in the long run, my aftermarket rims are nicer than my stock ones, and changing tires on rims affects the balance. Putting tires on rims, balancing them, means they are "always balanced". Not the other way around even though most shops balance both ways:
Guys & gals, I've never ruined a tire or had a rim dented by re-using the rims. And since I'd have them balanced anyway, it's not more expensive, for me. And I like the non steel rims during winter. Do what you like.
Of course, we will "do what we like". I've already done that a few years ago when I bought separate rims. The point of the discussion is what is preferable so we are discussing the details, and it helps people reading to decide what to do who are undecided.
I still can't figure out how the costs "are not more expensive, for me" regardless of balancing. There's no doubt that it costs more to pull tires off and on rims twice a year, unless you do it yourself, and few people have a machine to take tires on and off rims but many tire shops swap rims for free if you buy the rims/tires from them -- but none swap tires for free, of course. So how it cannot be more expensive for you only makes sense if you have a machine to do it yourself, or if you only plan to keep the car a couple of years. After that, you can buy good rims, like these, that are not steel, but an alloy with a "winter approved" coating:
R187 Gloss Gunmetal
https://www.replika.ca/productinfo.aspx?wn=r187&fn=gloss+gunmetal&wc=tesla&lang=en-US
At $80 a swap over, the average charge here plus tax, that's $160 year. At the price it only takes 5 years to equal the swap over costs for a nice set of new rims, that I like much better than the stock S rims (to the point that I bought 2 sets), and they are not steel rims, as you suggest. Plus, anytime tires are taken on and off wheels there's the potential for rim (and tire) damage and doing that twice a year to tires increases the odds of damage. Then try telling the tire shop that damage wasn't there prior. Another downside of swapping tires.
I pay less than $60 per swap,...don't know a place in Canada that does this for free - and would they balance them for free, too...it can be cheaper to swap the tires onto the same rims.
