After removing the USB stick from my 2.0 I got the "Communication Error. Service Required." message and all values were dashes. My heart sank when I couldn't even turn the car on. I got out of the car, took a few deep breaths, then noticed that it looked like the VMS rebooted itself or something since it went blank for a bit then came back up and my car worked again without me having to do anything. Whew.
Yeah, VMS lockups / watchdog reboots are not uncommon when reading/writing from USB sticks. It seems the software in the VMS is 'picky' about what sticks it wants to work with. I suggest trying another brand of stick.
However, I'm concerned that this is like pulling the power on a Linux system without requesting a shutdown first. Can anyone comment on whether there are risks to "rebooting" the VMS abruptly like this? In other words, I'm inclined to avoid a reboot unless it's the only option.
So far, this thread has indicated that there are no special precautions - that this is "just a reboot."
Maybe there's a way to trigger a soft reboot via Tattler or OVMS via the diagnostic cable?
Thanks. That what I thought. I opened and closed that thing like 15 times in quick succession (really wears on the tip of your finger to unlatch it that many times) but no dice.Supposedly the open-close-charge-port-door-a-bunch-of-times thing triggers a soft reboot.
I used a 1GB Tesla branded USB stick. Last time I did a log dump (two years ago) I used a different stick and had no issues. I need to figure out which one I used before.
So, I am having issues with my HVAC (no battery cooling) and will post that question separately, however, while in the service menu trouble shooting lack of cooling, I think I fat fingered an input and after exiting the service menu I received error messages ID: 1554 and 2096. Since then the car appears to have lost communication between the VMS and VDS and I can not get back into the service menu (password does not work). Charging still works and I was able to initiate and end charging cycles using OVMS (THANK YOU @markwj )!! I have pulled the 30 amp 12V fuse in the front but after reading through this thread appears I would also need to pull the battery disconnect which I do not want to do. So, my next course is to pull the 2 larger connectors from the VMS (black and blue) hoping that will reboot the unit and fix this issue. These seem pretty straight forward with regard to unlatching and latching (see video below) but any other thoughts on additional course of action? Obviously I will heed @markwj ‘s warning about the connectors, as being on your back in the footwell of the passenger area makes a simple task difficult.
Ampseal connectors mating and unmating @ 2:04
