The traction/stability control as I drove the Model S Performance at the Seattle Get Amped event was way, way too aggressive. On the second turn onto Aurora I came to a stop at the stop sign. It is an almost typical 90 degree right hand turn like you would see on a city block except that cross traffic does not stop and is moving at 40+ mph with limited visibility. I waited for an opening and came down hard on the accelerator to quickly merge into traffic. I was shocked when the car moved much slower than I was expecting and a whine emitted from behind the center console (not the back).
I would really love to hear from other test drivers. Did anyone else experience the heavy handed stability/traction control as I did? I have not really seen much mention of it which makes me think that maybe it was a recent change for safety reasons at the Get Amped events?
No, it's not. Only the simple-minded could possibly find it confusing. Get over it.And to all those who talk about breaks and breaking -- please stop. It's very confused/confusing. Braking, pls, with the brakes. No breaking with the breaks!
As for the regen with ABS, there's only a certain amount of "pull" the contact patch of the tires can apply to the road before slipping/locking. If you're on max regen and then hit the brakes, you get front tire drag added to the rear wheel drag. If that's needed in an emergency, fine. But for energy recovery, it's a straight deduction from what the rear wheels are contributing.
This will be different in the X-Perf (dual motor AWD) of course. In that system, the only value of emergency braking is to produce a deliberate skid, as the regen will already be applying all the static friction stress the tires' contact patches can handle.
Ditto on the steering feel. Such is the nature of drive-by-wire electronic steering I guess.
Do you know what your steering setting was set to? When I test drove in Fremont, mine was set to sport and it felt stiff and very direct. I liked it a lot. I have learned a lot in this forum since my tests drive but back then, I did not pay enough attention to traction control so I cannot speak to that. Also, I may be spoiled by my A4's AWD.
I felt the wheels break loose on my drive as well. For all the complaints about not having room to go 100, the turns on the Aurora route gave plenty of options for evaluating cornering -- at least to the degree I wanted to feel it in their vehicle.
I definitely did not feel the wheels lose traction but it seems you and others have... It really makes me want to go for another test drive...
Cued at that spot:Start at 7:35
I am pretty sure the steering is true rack-and-pinion, with an electric motor power assist. It's not steering by wire, like an modern aircraft. Yet.
First, to EarlyAdopter and Vegi - great reviews! It looks like you're comparing the Model S to sporty ICE roadsters... I'd suggest asking the local store for a Tesla Roadster Sport test drive, if they're still doing those. Or asking a forum member for a spin. Or, rent one in markets that have one or two (there's one in downtown Portland here). You will be more pleased in the handling and track feel. Still, the reviews you gave came pretty close, which make ME feel wonderful about getting my Model S to replace my grocery-getter. Thank you!!
Here's the video Francis posted earlier in the thread. Start at 7:35, this is where I'm making the right-hand turn. I started to make the turn and then stepped it to the floor. Somewhere around 20-25 I heard that muted tone - I'm guessing that same "whine" you heard. So I don't think it was breaking loose in the turn, but rather when I really romped on it. I could feel I broke them loose.
Yes, that's the sound. In videos it sounds like it is the electric motor but it is not. It is a whine or tone coming from behind the center of the dash which must be there to let you know that the traction control kicked in.
