After a few days of "off-nominal performance" (described below), figured out today the seat weight sensor for the driver's seat has failed. There were no obvious cable disconnections below the seat that I could see, so I do believe this is a failure above/beyond just a physical switch disconnect.
Observed symptoms of the sensor being out:
Car puts itself in park if in reverse with seat belt unbuckled
Car doesn't know the driver is inside, so unless driver has brake pedal depressed, car turns off as soon driver's door is closed.
No auto-Bluetooth connections - must manually connect every time.
Anyone else had this happen? Any other symptoms/failures happening or about to happen that I just haven't stumbled into yet? And the thousand dollar question - any one seen an estimate before? I'm half expecting the response on the app to be the entire seat has to be replaced.
