I had a problem recently with the door handle not presenting but, this time it was not a cracked gear… If you listen closely when it’s a cracked gear, you can hear the motor spinning but, this time there was no spinning motor and when I pressed the door handle, the door opened…
The fix:
I needed to open the service menu and calibrate the door handle.
If someone needs any more help let me know and I hope this helps someone!
The fix:
