Cracked charge handle on Gen 1 Wall Connector
I've stopped using this as I have a spare (Gen 2) wall connector. But I'd like to still have two usable WCs, and I'd prefer to be able to use the higher-amperage Gen 1. Can this be fixed?
Hello, did you ever get your unit fixed? My Gen 1 unit contactor solenoid broke and trying to find parts.
If you can read the info off the broken part for a number or some sort you should check out mouser, they are basically a 90's radio shack on steroids and stock all kinds of random electrical components, (resistors, caps, plugs, connectors, exc.)
I have not made any progress... Still have the cracked unit as well as a newer one (which I'm using exclusively). Good luck!
The handle itself should be the same regardless what version it is, so you could just get a broken one off eBay or something and do a 1 for 1 swap of the plastic on the handle.
