cali8484
It has already been solved in EU. These are grid-tie inverters so they shutoff in blackouts. The units are EU code compliant and safe. For the US. either reduce inverter power limit for 120V sockets or require 240V sockets (single 240V or 2 120V sockets from different phases). It's not rocket science. CPUC and similar agencies spend years to come up with laughable policies like NEM3 that supposedly make solar more equitable by pushing batteries!? While doing little to make solar for accessible.Usually the ones that plug into a wall socket violate code. Otherwise they would be great. Problem is you have a wall socket on a 1500w circuit. You plug in your 800w panel. You plug in a 2200w device. It works, getting 800w from the panel and 1400w from the wall, but it's drawing 2200w over wire meant for 1500w. Melt melt melt. Fire fire fire.
And there's the problem with back feed if your power goes off.
All that can be solved, but it usually isn't by these types of devices. It would be nice if the electrical codes did get updated to understand smart devices. If you can put the right sensors to assure you don't put more current in the wire than it should handle you should be good.
