Charge on Solar enabled... how to override and charge from grid when needed without disabling Charge on Solar first?
The issue is when I toggle Charge on Solar off, it's not easy to toggle Charge on Solar back on since it doesn't appear in the app all the time.
Is there a way to override and charge the car from the grid when Charge on Solar is enabled?
This is a problem with COS. Easiest way to do it without disabling is to move the left slider up to the charge level you want, and then start charging.
Reactions: arnolddeleon
Maybe I misunderstand the question...but would moving the "Charge Limit" 'sun' slider further to the right do what you want? When sliding that, the text says "Charge to (x)% from any source, then (y)% from solar". If you increase 'x', above the current charge level, it should charge from the grid.
Thanks! How about charging to 100% from grid (for roadtrips), it seems that is not possible unless I turn off Charge on Solar :/
Reactions: IronCoffee_Max
