I thought this was a fluke and was just going to ignore it, but it happened a second day in a row so I would like to understand what is happening.
Summary:
Yesterday I was pulling out of a tight spot and wanted to reverse. After switching into reverse (R) and slowly pressing on the accelerator, I started inching forwards instead of backwards. I repeated this a few times and this kept happening even after a software reboot and getting into and out of the car after switching to park (P). I verified with my passenger that I was in the correct gear and that the car was indeed moving forwards when in R. I've pulled out of this same spot 10+ times in the past without ever encountering this issue until yesterday and again today.
Details:
Relevant info:
I tried looking this up and could mostly just find people with this issue from a software bug way back in 2019. Surely that does not apply now, so I have no idea what could be causing this. Any help understanding what causes this and especially what to do in this situation would be greatly appreciated.
Summary:
Details:
- I switched from D to R, then slowly pressed down on the accelerator. To my surprise, the car started moving forwards instead of reversing.
- I looked back at the gear selection and confirmed it was in R. I slowly pressed down on the accelerator and once again the car started inching forwards.
- I then switched to P and reset the car by holding down the two buttons on the steering wheel.
- After waiting for the car to reboot, I switched into R and pressed down on the accelerator for a third time. The car started moving forwards again...
- Now I was about 2 feet from the car in front of me and didn't want to risk it any further. I got out of the car to check the space and it looked like I had barely enough room to get around the car in front of me without reversing. So I switched into D, turned my wheel all the way to the side and pressed the accelerator. The car started moving forwards and I was barely able to get around.
Relevant info:
- Occurrence 1 (Apr 28)
- Surface: Flat
- Stopping Mode: Hold
- SoC: 84%
- Exterior temperature: 51F (10.6C)
- Occurrence 2 (Apr 29)
- Surface: Flat
- SoC: 75%
- Exterior temperature: 56F (13.3C)
- Occurrence 1 and 2 happened at the same location.
