I'm still familiarizing myself with the DR650, but I am noticing some strange behaviors, at least on longer trips. At some point in the trip it will say "Blackvue for your safe driving, starting normal recording" again (like it does when you initially start your trip). This will keep happening, maybe every 15 minutes or so. At first I thought that maybe my power connection was faulty, but when you cut power to the unit, it seems to use a small battery or supercap to shutdown gracefully and announces so. I'm not hearing any shutdown messages, so I think it is being powered the whole time. I also get "please insert SD card" very rarely, which makes me wonder if the is a problem with the SD card, or the card holder contacts. I'm wondering if maybe there are thermal or other intermittent issue and the start of recording message is happening because the system is rebooting due to firmware crashes?
Anyone else having these sorts of problems?
My 650S keeps saying "resetting the time" then "restarting" about everytime I start driving about 1 or 2 minutes into the drive. When I pull the files the time is always right for before this message, I have about a 30 second gap in the recordings then things continue on as normal. I've already ordered a replacement for my current unit just to make sure it's the unit itself. Tried all variations of the stock 64GB card as well as others...formatted, firmware etc.
Yup. Same issues. My blackvue DR650s resets randomly while driving. Also, the direct wifi and cloud are impossible to use. The download is in a constant state of "buffer" and won't allow me to play the video. The app also crashes most of the time when doing this. I can pull the SD card out and play the videos just fine via pc. Anyone else find cloud use unusable?
I can't believe we have to use the Blackvue sd card. That makes no sense to me. Has anyone used an alternate 64gb or 128gb card without issues?
I read on dashcamtalk that some had success with the sandisk 64gb high endurance card. It also had a few amazon reviews reporting success with blackvue cameras. I just purchased one. I will report back when I get it. Thanks!
What kind of memory card did you use? The type memory card you used could cause the intermittent disconnect issues. Using Blackvue memory card would avoid/minimize the issue, but it's more expensive. I have had great experience using the following SD card with the latest firmware 2.007. I have been having it for a couple weeks now without connection issue, not annoying "check your SD card" messages when I used a different 128GB SD from from SP.
https://www.amazon.com/Samsung-mc128d-128gb-Uhs-i-Adapter/dp/B0118LR9Z8/ref=sr_1_fkmr2_2?ie=UTF8&qid=1473810428&sr=8-2-fkmr2&keywords=samsung+128GB+bravo+
The funny thing is, I am running the Blackvue branded card. It's a 32GB MLC Class 6 card. It came included in the price of the unit - I didn't even have to install it. I will try some other cards - I make a product that uses microSD, so we have a large variety of cards around here for testing.
Just installed the sandisk 64gb high endurance card. I tried formatting via PC first. The cloud was COMPLETELY unusable. It would crash almost immediately. This morning, I reformatted in the camera and then tested the wifi direct after my commute. It worked great. I will test cloud play back when I get home!
On the PC, I actually formatted via the blackvue downloaded app (which I think defaults to a FAT32). If the cloud still doesn't work when I get home, I will try to reformat via Windows FAT32. Man, this thing is touchy.Did you make sure that you formatted it using Fat32 using Windows, MsDOS when using MAC OS?
I have the dr650s (latest model). There was a recent firmware update, but it was 1.002 (released 8/26/2016). I am up to date.Firmware 2.007?
