Vendor Affordable Monoblock Forged! VS Forged Wheels
Tesla Model 3 Performance with Performance Upgrade sporting the VS Forged VS10!
These VS10 wheels are done in the Brushed Titanium finish
20X9 | 20X10.5
Thanks Josh, it would not have happened without your help and patience. ;)
I bought these as my winter wheels, but like them enough I may use them in the summer. If not, I'll likely be placing an order for a set of summer wheels this spring. :D
No problem and haha, let me know! I got you covered.
What offset are these? Coming time to order and gotta make a decision...especially since Tesla sent the 5k already .
We did 9 +32 and 10.5 +45. We felt like it could definitely come a little further out in the rear.
Any pics of 19” VS02’s on a P3?
Also, do you know if any of your P3 customers experienced significant range increase (wh/mi drop) with the new tires/wheels.
Near as I can tell comparing my Teslafi Wh/Mile data for my commute I gained at least 5% after moving to the VS08's in 19x8.5+30 fitment from the stock 20" setup. I also moved to snow tires and its been colder (running heat more), so the gain may be greater. I'll need more sample data to be sure given each day's drive differs based on snow on road, temp, traffic, my inclination to push the fun pedal, etc. Some drives show double-digit gains compared to same drive a month earlier on stocks at nearly same max speed, ave speed and fan speed setting of car, so I'm hopeful it does turn out to be 10%+.
Edit, another thing that may point to 10%+ is that I have to keep my car outside and lately even with pre-conditioning battery and car (charging right before commute) I do have the reduced regen msg, which I never got back when I had the 20"s on. Since my commute into work drops 2000ft in elevation the first 7 miles, I likely am not gaining as much back in regen with the colder weather as I did prior.
Thanks for the feedback. That’s good to hear. Looking forward to seeing more installed pics.
Can you assist? I love these. 2016 Model X -- 20" --- I have 275/45/20 in the rear and 265/45/20 Scorpions that I just mounted to replace my OEMs or I would even consider moving up to 22". Shipped to 20774.
You all put my wheels on my Genesis Coupe years ago when you were a forum vendor over there. Look forwarding to hearing from you.
VS Forged VS03 ordered in a Gloss Black Tinted Face finish.
What a beautiful finish!
Reactions: dmd2005
Can’t wait to get these wheels and it’s too bad I have to wait till spring to install these. I might just slap them on this weekend for a day for some pics since it’s suppose to be dry and sunny.
Josh was super easy to work with and these are the second set of wheels I’ve ordered from Get Your Wheels. Highly recommend their service and wheels.
I'll send you a PM.
Thanks for the kind words! Your set blew my mind when I opened up that box.
Hey Josh,
Put the VS03 on and they look awesome. Looks aggressive and stylish and the tinted face looks either black or silver depending on the angle or light. I couldn’t be more pleased with the final finish.
The only suggestion for people with the Performance Model 3 is to get some antiseize compound to put on the lip in the hub because it corrodes and I had to use a Scotchbrite pad to remove the rust so that I didn’t have to fight seating the wheel over the hub.
I’ll take some more pics when it’s sunny. I’ll probably take them off on Sunday and ceramic coat them with Cquartz for the wheels.
