I have a large two story stone fireplace chimney which is half inside and half outside. Faces southeast. It's a massive heat sink. I've considered putting glass on the outside to capture sun heat and insulate it. I'll have to spend some time this winter looking into this project. I don't think I'll need to move air. Just heating it up during the day should keep the inside warm at night.
An idea for an experiment - use some heavy plastic (green house type). See if you can tell any difference.
Fold, don't cut plastic so you can easily re-use for green house.
After this experiment, use the plastic and make a small green house for your gardening.
Suggest simple A-frame for simplicity. 8' a little short 10' or 12' better. Depends on the room you have.
Some do simple like a tent, use stakes to keep plastic off plants and just throw plastic over the top of the garden 1 month early in the spring and early fall to extend.
IF you have constant wind, then it might help. Otherwise, sun heats up rocks just fine. You may only need the"extra heat" in the evening anyway. Blankets are cheaper than heating, and so are sweaters during the day.
All of course depends on your cash flow - how much you care to spend, how much you worry about the looks vs experimenting and seeing what works. Keep it simple. Many ideas you can find with internet searches.
good luck, have fun, keep it simple. hint: most greenhouse collect too much heat, so surprisingly good ventilation is sometimes needed to expel the extra heat. You certainly don't want to spend money on heating/cooling your green house.
Ours in shade of trees about 1/3 of the day and plenty warm enough.
and the ends are open - plastic just hangs down to frighten off the deer.
Too tall hoop design slightly over 12' tall 30' wide - put holes in the roof plastic to drain water which also waters the plants when it rains. but the A-Frame simpler. No more hoop style for me.
