J Juno Garf Member Mar 22, 2023 14 7 Queensland Mar 26, 2024 #1 Mar 26, 2024 #1 Can anyone identify what is the issue here, only occurs on right full lock. I've contacted Tesla service but their response was dismissive
J Juno Garf Member Mar 22, 2023 14 7 Queensland Mar 30, 2024 #2 Mar 30, 2024 #2 Nobody? Surely this isn't unique. Upvote 0
J Juno Garf Member Mar 22, 2023 14 7 Queensland May 16, 2024 #3 May 16, 2024 #3 Turns out it was corrosion on the contact patch between the rim and hub. Solution: Remove the wheels, clean the surfaces in contact and lubricate Reactions: slzeal Upvote 0
D dsgerbc Active Member Jun 4, 2019 1,179 1,042 Michigan May 18, 2024 #4 May 18, 2024 #4 Juno Garf said: Turns out it was corrosion on the contact patch between the rim and hub. Solution: Remove the wheels, clean the surfaces in contact and lubricate Click to expand... That can't possibly have been it. If your wheel/rim moves against the hub, your wheels nuts aren't properly tightened. Upvote 0
