Squeaks and fix
gigg
38
39
NC
In case anyone else has this issue. I have had a suspension squeak for the last year since new and replaced FUCA twice. Tesla installed one, then i installed an MPP.
I finally found it. The front under tray was rubbing against the FLCA over bumps making similar sound as the FUCA squeak. Creaky wood floor squeak, "it was bad". I used a dremel to take down the ribs. Fixed
I have a rattle top left corner of the dash under the mesh. I can put a little pressure on it to resolve it, so Im guessing it is a speaker? I havn't researched how easy it is to get to it, but that will be next...
Mine would go away after being lifted for a short time as well, which is hard to understand, unless the tray would somehow get relief for short time from being in that position.
I greased with a needle everything i could find and thought a fixed it for a couple of days. I spent so many hours, going to a service center, looking for and greasing, replacing FUCA, for the plastic rubbing. Even having a rock break my windshield on the way back from having FUCA replaced, a 4 hour commute, all for no reason. "Exhausting"
So hopefully this will help someone else from going through all that.
Reactions: untilcomplete
