I recently got rear fog lights to replace the reflectors on my LR AWD 2022, here are the ones I got:
I bought the plug and play smoked (Smoked lens B)
The install was straightforward-ish but was more work than I had imagined when I started. There are a few ways you can go about it but I decided to partially remove the rear bumper so that I could snake my arm down more carefully guide the wire. Notes / tips for installing:
- Do not use any plastic pry tools to pop out the reflectors. This will not only break the tabs of the reflectors but very likely dent the paint where you are leveraging against. This is a large reason I removed the bumper to squeeze the reflectors tabs to release. This is not easy to do but worth it.
- When removing the wheel well protector there are 3 expanding push connecters, 2 twist on screw type, and one T25, find them all, watch videos.
- To run the wire into the hole where to existing tail light goes, I added a little tape to soften the edge since the new wire will be pushed between the metal and the gasket.
- when removing the tail lights push type connector, you do not need pry tools as these will damage the car. Remove the two nuts and top plastic nut, then pull/twist towards the center of the car to release the final pressure connectors.
Here is not great photo of them installed with the car off. I can upload more if anyone wants to see them.
