Luisito
Wow, three times! This is costing Tesla and us consumers. They need to get this fixed asap!!!Yes, covered under warranty all three times they have replaced my half shafts.
Yeah, they didn't really know how to fix it last year. Hopefully by now they have figured it out. I think communication between the service centers and engineering is not great.Wow, three times! This is costing Tesla and us consumers. They need to get this fixed asap!!!
There does seem to be some variance between the Plaids. Every single one I've driven has the vibration to some degree. A Turo rental 2021 Plaid I had in California was the most subtle, and that had many thousands of miles on it. My 2021 didn't develop the vibration until 1500 miles, and I knew what to look for and had experienced it with @jebinc 's car, and he also noted mine did not have the vibration, initially. Ironically, my vibration developed while I was on the way home from hanging out with @jebinc , so I figured he sabotaged my car with his mind.Was it covered under warranty? I’m not sure I trust it being the same part number. Tesla is good at updating revision/part numbers for any type of changes. Definitely following this thread.
My vibrations started over 1000 miles. Exactly as described in this thread. Very subtle but noticeable once it’s there. I feel it most from the accelerator pedal. I’ve been following @WilliamG Model S post’s/dilemmas (thanks for your contributions).
I lucked out with my Plaid. Great build, only issue to date is this vibration. Not even the rear tire wear, etc…
I've driven two '22 LR model S that don't have the vibration. One had 4k miles, the other 13k.There does seem to be some variance between the Plaids. Every single one I've driven has the vibration to some degree. A Turo rental 2021 Plaid I had in California was the most subtle, and that had many thousands of miles on it. My 2021 didn't develop the vibration until 1500 miles, and I knew what to look for and had experienced it with @jebinc 's car, and he also noted mine did not have the vibration, initially. Ironically, my vibration developed while I was on the way home from hanging out with @jebinc , so I figured he sabotaged my car with his mind.
I've driven a few others, and they all have it, of course. My current 2022 Plaid vibrated from new, straight away, no break in. Initially running the car in Medium suspension height reduced the vibration, and now it only increases the vibration. Wild. Even in Low I can feel the vibration from around 31mph, and I'm at 3200 miles now. After using some lowering links on the front for a small reduction in ride height, the vibration is somewhat reduced, which is a relief. I no longer feel the vibration in the low 30s, and now only feel it around 40-50. So it's clear there's some variance between builds.
Of course, if Tesla were to reach out and use my stupid car as a 2022 patient zero, they could figure this out in no time, but I suspect they:
1.) Don't know, don't care, - at least not at a high level.
2.) Know, but still don't care, as this is a low volume vehicle.
3.) Know, but are sweeping it under the rug as it would involve a lot of annoyed customers if they just blanket admitted to the issue. I guess that ties into the prior point of knowing, but not caring.
For the record, not a single passenger has ever, ever complained about feeling the vibration when I'm driving, even if I'm driving constantly around 40-50. Not. A. Single. Passenger.
Meh. Hopefully @n2mb_racing continues to get good results from his "engineering sample," but I'm still so dubious. Doesn't make sense they'd be putting an engineering sample on his car. That testing could have been done already...
YES! Wheels do not matter. Junk.Are people with the smaller 19s also having this problem? Or is it just us with the 21s?
Yeah, they are really giving him the half-shaft!Wow, three times! This is costing Tesla and us consumers. They need to get this fixed asap!!!
Just checking in. Bought a used '21 Plaid with 30k miles and definitely have the 40-50 mph shimmy....
And the 21 inch tire wear.
I would say closer to 100% either way. Few report no vibration. Definitely more than 50% (new or used).That's probably the main reasons most used Refresh's are put up for sale so early in their life. I think you're pretty much guaranteed to have these problems if you buy a used one, and 50/50 if you buy a new one.
TWSSI started beating on the car this morning. No vibrations so far... The new half shafts might be the cure...
Still the same old part number, but the service manager said it was an "engineering sample" of a new version of the part from the supplier with tighter tolerances. Invoice below.
Agreed. I'll post up each week as I get more miles on it.I would be curious to see when they roll the part number officially. Going to a SC now to tell them to get an Engineering sample of the same part number you can imagine how that will go.
Good to hear you are having good results now, but would like to get your feedback a couple thousand miles later.
FYI.. Just saw this on the Service Manual Release notes for this week:
Halfshaft replacement..
Wonder when this was developed, just got my March MSP.. only had it a week, so too many new things to look out for, not sure if I've really had any vibrations or not..
This is for 2021+ Model S
Yup I definitely have noticed this. Thought it was the pavement. My ride height is always on Medium.
Low is different than sport.Check your ride height at freeway speeds. Mine automatically puts it in low every time, so you are probably riding in low without knowing it.
My theory is sport keeps the front from lifting under hard acceleration causing traction loss on the front wheels. ( I said theory) this may well be a whole different subject.Check your ride height at freeway speeds. Mine automatically puts it in low every time, so you are probably riding in low without knowing it.
