What I noticed when I supercharged for the first time ever yesterday was that it calculated/calibrated for a long time. I know it slows down as you get to full charge but that last 1 mile it was like 10 minutes. It had a set limit stated of 272 miles range and was charging at 1-2 miles and hour in the end. At home it hits 273 miles(probably not actual) and completes it's charge at a consistent rate. It slows a little then hits 100% and stops right away no calculating/calibrating. I use both words because my phone said calculating at the top but the Tesla screen said calibrating at the top. I was able to stream Sling and realized I need to turn off phone bluetooth connection to get sound to work from browsing.
Tesla probably try to use terms that make sensemto people even if it actually doesnt
Make sens.
When reaching the top Voltage the charger
Can not (must not) go over the maximum allowed voltage. For Teslas lithium ion this is 4.20V/cell, for LFP I’m not 100% sure but around 3.65V or so.
It is the difference between the cell voltage and supply voltage that causes current to flow and charge the battery.
If there is no difference in voltage, there will be no current charging the battery.
When the charging voltage can not (must not) be increased the charging current will reduce as the battery voltage increase.
In the end there is very little difference in voltage and because of that, very little charging current. This is one part of the explanation.
The other part is that the cells will differ on voltage, due to slightly different capacity and sometimes slightly different SOC in the cells.
To adjust this, cell balancing is performed at high SOC to make sure all cells reach100% SOC or close to that.
The cell balancing is performed by burning off voltage from the cells with higher voltage. This takes time, as the ”burn off” function is not burning energy that fast.
So, the long time comes from charging slow in the high end plus the cell balancing.
In reality it is not ”calibrating”.
