I am noticing a weird battery charging pattern since I started using mobile charger with 240v/15-50amp outlet.
2023 Model S, six months old. About 5k miles. Mostly charged at home with mobile charger 120v/12amp, most of the time up to 55/60% (except for three times at supercharger, once after I bought the car and two times couple weeks ago on a long trip).
Two days ago I got the 240v/15-50amp outlet installed. Charged the car to 60% (still using a mobile charger and not wall charger, it charged at 32 amp) and kept it plugged in. The miles shown after completing the charging was was 243 miles. After 3 or 4 hours I saw the range gone down to 235 miles. I thought that was weird but ignored it (I used to see a mile to 2 drop few hours after completing the charging but not this much). After 30 min or so, it went down to 233.
Last night again charged to 60% (must have finished charging at 6 am, based on the schedule). At 7 am it showed 58%. Not sure what is going on. When I checked the app first time in the morning it said it had added 11 kwh but when I checked again in 30 min or so it said it had added 10 kwh.
When I do not charge the car but just keep plugged in, I do not see range drop but I do see this pattern after the car is charged. Wonder what it is. May be BMS is not calculating the battery percentage correctly, or somehow battery is losing the charge? It did not do this when I was charging with 120v/12 amp. Not sure if its just a coincidence. I am going to go back to charging with 110 v and see if this happens. But wanted to see if anyone on the forum might know what may be going on.
