Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Connector Protector
  1. #1
    Senior Member Lloyd's Avatar
    Jan 2011
    San Luis Obispo, CA
    Connector Protector
    NEW ANTI-THEFT DEVICE STOPS ELECTRIC CAR CABLE THEIVES AND SECURES CHARGE CORDS FROM UNPLUGGING. THE SLEEK DESIGN IS COMPATIBLE WITH ALL ELECTRIC CAR CHARGING CABLES
    SAN LUIS OBISPO, CA. (6/25/2012) –You may have heard recently about EV owners being ticketed for being unplugged while their vehicle was unattended at a charging location. Someone else unplugged their EV and left them vulnerable to ticketing. AB 475 is an example. If you own an electric vehicle or plug in hybrid, you know the cable you use to plug into a charging unit can be a bit pricey - $1,500 or more in some cases, making them an attractive target for cable thieves. The connector protector provides additional security to your cable while you are away.
    Now there is a simple and easy solution that uses the weight of your electric vehicle to secure your valuable electrical connection without damage to the cable – Connector Protector. Upon first glance Connector Protector may look like a standard wheel chock, that is until you notice the multiple slots for securing virtually any size charging cable up to 35 mm in diameter. Once you actually pick up the unit you can feel just how the high-grade thermoplastic construction is strong enough to resist cutting,warping and the weight of any vehicle. The simple design makes Connector Protector easy to use, works with virtually all electric vehicles on the market today and at just $40.00 it is affordable protection.
    Connector Protector was founded in San Luis Obispo to provide electric car owners with peace of mind while recharging their vehicles. Connector Protector is available exclusively at Connector Protector | Protect Your EV Charging Cord and retails for $40.00.
    If you'd like more information about Connector Protector please visit Connector Protector | Protect Your EV Charging Cord or email us at Info@ConnectorProtector.com.
Size:  780.7 KB Name:  connector-protector3.jpg
    SP-2823 XP-12
  2. #2
    Member wiztecy's Avatar
    Apr 2012
    Santa Cruz
    I love the idea and promote people inventing but it seems like a multistep thing for that that you have to 1st:
    1) Get out and get your charger Cable ready
    2) Get the wheel chalk / lock out
    3) Put the cable under the chalk and ensure the reach is correct for the cable
    4) Get in the car, back it up to the chalk and now you're cable is locked.
    Where I've seen that a simple cable lock around the wheel and a padlock locking down the charge cable to the locked cable around the wheel is simpler and can be done in 1 step.
    Also a Lock and cable should run $20.
    So that's an option if your strapped for cash and time.
    You can pick up a motorcycle lock that has a motion alarm on it, its very high pitched. So if someone moves it / grabs the cable the alarm sounds peoples attention and deters thiefs.
  3. #3
    Jan 2011
    San Luis Obispo, CA
    I agree that use every time would be tedious, but don't you see the benefit when you park for extended periods such as airport parking?
    The lock and cable does not work as well as it allows the cable to slide through. The connector protector puts enough pressure to keep the cord at your vehicle only. The moulded plastic only weighs 12ounces and can be stored easily in the frunk cubby!
    Example: Tesla Santana Row complained that The EVSE'S in the parking structure behind the store were being used to charge the demo Roadsters. The employees plug the demo cars in when they leave for the night. During the night the cars were being unplugged I assume to charge other Teslas. In the morning the employees were upset because the demo cars were uncharged and not ready for customers.
    SP-2823 XP-12
  4. #4
    Model S Sig Perf, VIN 586
    Apr 2012
    Rocklin, CA
    Was told at the event today that the S doesn't allow removal of the connector without the key nearby. I guess it just locks like the doors do.
    I've no idea how that would actually work. Also it seems like that would be a problem for the UMC where it has a part connected to the car that can't be removed but also a part adapting the J1772 or whatever connector. Dunno how the lock and cable would solve that either (maybe in addition to?).
    PLEASE NOTE: Posts are the copyrighted intellectual property of the author, and are intended as part of a conversation within this forum. My words may NOT be quoted outside this forum, without my expressed consent.
  5. #5
    Jan 2011
    San Luis Obispo, CA
    Quote Originally Posted by Jason S View Post
    I was told that any tesla key will unlock the charge cable. I will try and verify that during my drive tomorrow
    SP-2823 XP-12
  6. #6
    Apr 2012
    Santa Cruz
    Yes, I can see how the pressure of the wheel could keep the cable from being pulled. Good point and an advantage of the design. I recall seeing a forum member posting a pic of the cable/lock idea and it appeared that the log compressed down onto the cable which also prevented the slip, not the same forces of pressure of course but it looked like it kept the cable from creeping through. It would take some trial and error to find the right lock. Appreciate the link and the reply!
  7. #7
    Apr 2012
    Rocklin, CA
    Quote Originally Posted by Lloyd View Post
    Good luck! It was just an offhand remark from one of the Tesla folks when I was fiddling with the VIN 0043 beta's charge door (closed it then had to search for how to get it open again; thru the console).
  8. #8
    Jan 2011
    San Luis Obispo, CA
    Quote Originally Posted by wiztecy View Post
    The public cable if not your own will have varying diameters depending on the manufacturer and the power being delivered.
    SP-2823 XP-12
  9. #9
    Aug 2010
    Woodinville, WA
    I thought it was any cable could open the charge port door (common rfid or something), but hadn't heard any specifics on the locking mechanism, that could be keyfob based?
  10. #10
    Jan 2011
    San Luis Obispo, CA
    I set up a club discount for the anyone in the TMC who is interested in purchasing a Connector Protector. $10 off!
    www.connectorprotector.com and input coupon code teslaclub10
    This offer is valid on the website until December 31st 2012
    SP-2823 XP-12
  1. Wall Connector vs. Extra Mobile Connector Cable?
    By mknox in forum Model S: Battery & Charging
    Last Post: 09-14-2012, 01:18 PM
  2. ACEA Recommends one connector for the EU
    By widodh in forum Europe
    Last Post: 09-26-2011, 09:41 PM
  3. HPC connector on EBay
    By pgwoosley in forum Tesla Parts for Sale
    Last Post: 08-04-2011, 10:04 AM
  4. Name that connector!
    By Slackjaw in forum North America
    Last Post: 07-07-2011, 06:02 AM
  5. How to open the MC120 connector
    By DaveD in forum Technical Discussion
    Last Post: 06-03-2009, 11:45 AM
