Sufficiently advanced magic is indistinguishable from a rigged demonstration.
DISCLAIMER:
1. Do not copy anything that I post outside of the TMC forum without permission.
2. Any advice or opinions posted here are to be taken as my personal opinions only. There is no implied warranty, fitness for purpose, or official statements from any company I may have been or am affiliated with.
3. Even the best recommendations are wrong when used inappropriately.
If you look at the various screenshots of the touchscreen on TMC they show 2 modes: standard and range. I'm not sure anyone knows whether a storage mode explicitly exists, or how it's entered.
Edit: Here it is
http://www.teslamotorsclub.com/attac...1&d=1338043600
very cool,
Thanks!
SP-2823 XP-12
Since the wire and breaker likely add a modest amount of extra cost i would install 100amp if you can but set the car to charge at 40 amps. This is what i do. For the Roadster 40 amp is the most efficient as higher rates tend to kick on the ac for battery cooling. Then on those few occasions i can rapid charge or help out a fellow roadster charge on a trip.
The charger makes this easy as the GPS tracks the location so it knows home is 40 amps. The lower current is also easier on the utility. Again two taps and i can override.
Nema 6-50 vs 14- Today I had an electrician look at my outlet today and I can easily have my correct outlet converted to the 6-50 for about 100 bucks otherwise what is the reason to convert to a 'recomended' 14-50, 4 prong as opposed to my current 3 prong outlet? Both have identical 31 amp charge rates...
Model S. P5810
The only reason NEMA 14-50 is recommended is because that's what you find in the wild (at RV parks, campgrounds, etc) in North America. The fourth pin adds the neutral line so you can 120V or 240V, since a RV might have 120V appliances. The Model S doesn't actually use this neutral pin, so you could use NEMA 6-50 (and that plug is available with the UMC), but you'd also want the 14-50 to charge in the wild.
Both are actually good for 40 amps continuous, 50 peak (where the "-50" comes from).
