Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 30
Thread: Range after 15K Miles
  1. #11
    Lightning Green Fairytale Dragon's Avatar
    Dec 2010
    Italy
    Quote Originally Posted by MAPC View Post
    I hope that this isn't a redundant question, but I am a new owner and trying to determine if what I am experiencing is to be expected or if there is an issue.
    When I charge, it turns off (stating 'fully charged') at 185 miles. This is in Standard Mode.
    Is this to be expected on a battery (that has been well cared for) with only 15,000 miles on it?
    Any direction you can give would be appreciated.
    Good numbers compared to mine. I recently hit 10.000 miles and the ideal range in standard is never above 182 miles.
    Tesla Roadster #570 EU
    Status | Your Roadster has over 17000 km on the odometer, 293 km range on standard charge.
  2. #12
    Member wiztecy's Avatar
    Apr 2012
    Santa Cruz
    Curious when everyone is taking their charge numbers from? When the charge has just stopped or when the battery has settled down at 15, 30, or 60 mins? Note the battery will settle down to a lower number once it has equalized the voltage in the battery.
  3. #13
    Sep 2006
    Pennsylvania
    At 41,500 miles my standard mode charge settles to 167 miles.
  4. #14
    Senior Member strider's Avatar
    Oct 2010
    Bay Area, CA
    I have 16k miles at standard mode settles to 186. Although I left it plugged in Standard Mode for a week when I was out of town and this morning it was at 180. Assume it'll go back up after a run to work and back.
    Twilight Blue Roadster 2.5 - #1098 / Grey Model S Performance - #1459
  5. #15
    S105/ Roadster 189 Sparrow's Avatar
    Dec 2010
    Marietta, GA
    At 21,500 my #189 settles at 166 miles down about 10 miles since last Fall.
  6. #16
    When I got my car with less than 500 miles on it, standard mode charging would put me at 189-191 miles. Now after 23k I'm getting 180 - so about 5% after
    a little more than a year.
  7. #17
    Roadster #404, Sig #26
    May 2012
    Bay Area, California
    At 22,000 my #404 charges to 175 miles in standard mode. Have filled it up to range mode maybe 6-8 times in 3 years
  8. #18
    Roadster 919, S 2006 Doug_G's Avatar
    Apr 2010
    Ottawa, Canada
    Blog Entries
    Quote Originally Posted by augkuo View Post
    Your pack probably isn't balanced. Do a Range mode charge, let it sit a couple of hours, then take it out for a spin to drop it back down from 100% charge. See if that improves your standard charge range.
    Roadster #919, Model S #2006
    Moderator: Tesla Motors , Electric Vehicles, EVents, Media
    , and Canada sub-forums.
    To the media: If you want to quote me, please contact me directly. I'll be happy to talk with you. Taking random postings out of context is not appreciated. Thanks!
  9. #19
    Apr 2012
    Santa Cruz
    Doug, would standard mode also equalize them? I read from a tesla tech email on this forum to do 3 standard mode charges and let it sit to equalize for some time on each charge. Now the battery "gas gauge" (what each battery has) typically need to be recalibrate once in a while. For that at least a 95% charge and then discharge down to 5% recalibrates it. That is for consumer electronics with the LIPO packs, I would believe it also applies here so your range mode charge does make sense. And yes when the battery equalizes/gas gauge is recalibrate you can get more miles and an accurate reading of charge/discharge state.
  10. #20
    Apr 2010
    Ottawa, Canada
    Blog Entries
    Yes, standard mode charging will slowly balance the pack - it can take a couple of weeks. Range mode apparently does more balancing than standard mode. Never beeen explained why or how, but from observation it does appear to be true.
  1. Replies: 14
    Last Post: 12-17-2012, 02:58 PM
  2. Replies: 4
    Last Post: 09-19-2012, 08:17 AM
  3. Dash range does not match console charging range?
    By jordanthompson in forum Roadster
    Last Post: 05-27-2012, 01:04 PM
  4. Replies: 19
    Last Post: 11-14-2011, 12:13 AM
  5. Miles Javlon
    By DDB in forum Electric Vehicles
    Last Post: 08-11-2007, 02:56 PM
