Page 92 of 137 FirstFirst ... 4282888990919293949596102 ... LastLast
Results 911 to 920 of 1362
Thread: Tesla Supercharger network
  1. #911
    Model S 03182 ElSupreme's Avatar
    Jan 2012
    Atlanta, GA
    Quote Originally Posted by Enadler View Post
    Actually I believe Superchargers are all Solar powered.
    Well they have solar panels on them. They are all grid powered. But the thought is the solar panels will generate more aggregate power than the superchargers put out over a period of time (probably a year, to average out summer and winter). But if they were solar powered then you wouldn't be able to charge at night, when it was cloudy. That would not we very convenient.
    Think with dispassion; Speak with equanimity; Act in calm.
    Moderator - Southeast, Future Cars
    Do not use this material outside of Tesla Motors Club without attribution and permission.
  2. #912
    P631 hans's Avatar
    Sep 2012
    Menlo Park
    Quote Originally Posted by JRP3 View Post
    No. In fact even the ones with solar panels don't supply the full power from the panels but draw from the grid, the panels just supplement and feed power back to the grid when no one is charging.
    Agreed. I used a online solar PV system calculator to estimate the size of a system that could generate ~90KW, at peak, in California, and its about 9,500 sq-ft. This would only supercharge one car, and only at peak time of day. Given that many of the supercharger locations have 2 or 4 or perhaps more charging spots in the future, they would have to cover many more parking spots than just the ones reserved for supercharging if they wanted to power the whole system from solar. The same problem exists for the idea that the grid connection would be the same capacity for grid to charger as it is the other way from solar panels to grid.
    It is possible to cover the entire parking lot or the roofs on all the surrounding buildings but I don't think the plan is to do all that.
  3. #913
    Senior Member jcstp's Avatar
    Feb 2011
    Belgium
    wasn't there mention that those superchargers would be connected to a battery?
    then they would not need high-power connection to the grid!
  4. #914
    Model X #1417
    Aug 2012
    Boston
    Quote Originally Posted by ElSupreme View Post
    There is the problem that most of these locations would most likely need a larger power feed than they currently have. This service upgrade can be VERY expensive.
    I bet a lot of their Supercharger location requirements is nearby large power feed to tap off of.
    But since they already are in commercial establishments, particularly the service centers, they likely already have 3 phase power, a parking area, and a building so they're well on the way. A green field Supercharger installation has to start from scratch, buy or lease land, put in a new service, and construct the facility.
    It still seems to me that the marginal cost of adding one to an existing Tesla facility would be significantly less than building one from scratch.
    At a sales facility, I'd also think that potential customers seeing and talking to owners charging there would make them feel better and existing owners might wander through the showroom and think about another car or an upgrade.
    As far as completely solar powering a Supercharger, that would seriously not work in many areas of the country, e.g. New England. After the first few days of overcast weather with intermittent sleet I don't think there'd be much charging going on.
  5. #915
    Senior Member JRP3's Avatar
    Aug 2007
    Central New York
    There was talk of that, but so far none are, and it would raise the cost of the system.
  6. #916
    Jan 2012
    Atlanta, GA
    Quote Originally Posted by RDoc View Post
    The real problem is whether or not their copper is fat enough. A single supercharger will pull about as much power as 20-40 houses (wolfram alpha). 100kW is a TON of power to pull instantaneously. Most commercial places won't have thick enough copper.
    In fact you aren't going to bring in that much power on 480 3phase anyway it requires too much copper, you are going to bring in much higher voltage and step down near the supercharge units.
  7. #917
    Model S - U.S. P - #1649
    Jul 2011
    Cheney, WA (near Spokane)
    Quote Originally Posted by jcstp View Post
    If they put HPC, asside Superchargers, people can choose fast or fastest charge!
    Would 4 hpc cost more than 4 superchargers?
    I guess once the basics of a supercharger are installed, adding berths will cost +/- same as adding a hpc! no?
    For that matter, I think it would be advantageous for all if one used the supercharger to the point where the charge rate dropped and then go to the HPC to top off while the supercharger would then be available for the next user.
  8. #918
    Aug 2007
    Central New York
    Pretty sure all high voltage lines use aluminum, not copper.
  9. #919
    Yep, aluminium wrapped steel lines.
  10. #920
    Power12 Babylonfive's Avatar
    Feb 2011
    Cedar Park (Austin), Texas
    Quote Originally Posted by qwk View Post
    I'd like a response from someone with AC transmission/subtransmission knowledge, but I believe if they used intermediate feed voltage of 3-4kV, the current would be much lower, and this is a standard industrial feed voltage.
    www.power12.com ----- Sweet Silver Sixty: 60KWH, Non-perf, Silver ext/Black int, Pano, Tech, 21" Silver wheels
There are currently 2 users browsing this thread. (1 members and 1 guests)
  1. fengshui
  1. Suggested Tesla Supercharger locations in Florida
    By Larry Chanin in forum Florida
    Last Post: 05-13-2013, 11:17 AM
  2. Suggested Tesla Supercharger locations in Texas
    By dsm363 in forum Mountain/Southwest
    Last Post: 02-25-2013, 08:52 AM
  3. Tesla Supercharger locations
    By dsm363 in forum Wiki
    Last Post: 01-09-2013, 07:02 PM
  4. Supercharger Event 2012/9/24
    By iridium in forum News
    Last Post: 09-28-2012, 12:44 AM
  5. "Supercharger" plans for Germany (Current HPC network)
    By TEG in forum Netherlands, Belgium, Germany, Austria, Switzerland
    Last Post: 12-13-2011, 11:34 PM
