Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Charge in Standard, Drive in Range
  1. #11
    Roadster #1144 + Sig 114 dsm363's Avatar
    May 2009
    Texas
    Quote Originally Posted by Aspirant View Post
    Tesla's recommendations amount to best practices for drivers who want to apply minimal thought to the car's operation. Those who care to understand the principles at work can optimize.
    I care to understand the principles at work to optimize the battery too. As wiztecy said, you then might want to keep the SOC at 50% as often as possible in that case. There are many small things you could do that might be nicer to the battery than charging and driving in standard mode as Tesla suggests but we're talking about some unknown, likely fraction of a percent difference over a few years. You're likely right that it may be nicer on the battery but I also bought the Roadster to have a little fun. You're welcome to charge in standard mode and drive in range mode but I'd rather have full power in the sports car I bought.
  2. #12
    Senior Member strider's Avatar
    Oct 2010
    Bay Area, CA
    Temperature is not the only factor in battery wear. There is also just plain use: charging and discharging. Fifty % less available power results in less overall battery use.
    True, but you don't need to drive in range mode to do that. You can just be gentle with your right foot.
    My point being that Tesla already does everything they can to balance performance and battery life. I would just charge and drive in standard and enjoy the power when you need/want it.
    Twilight Blue Roadster 2.5 - #1098 / Grey Model S Performance - #1459
  3. #13
    mod squad bonnie1194's Avatar
    Feb 2011
    Blog Entries
    4
    The only time I drive in range mode is when I need to maximize miles on a road trip (like, say, to SoCal). And it helps a great deal. I've never matched the mileage using range with standard- because, yes, 'My name is Bonnie and I have a lead foot.'
    PLEASE NOTE: Posts are the copyrighted intellectual property of the author, and are intended as part of a conversation within this forum. My words may NOT be quoted outside this forum, without my expressed consent.
    __________________
    Moderator: Model S, Model X, EVents, California, Pacific/Northwest, and Media
    TESLIVE Committee Member
  4. #14
    Roadster 919, S 2006 Doug_G's Avatar
    Apr 2010
    Ottawa, Canada
    Blog Entries
    A while back I ended up getting into the "reserve" charge range, where the Roadster no longer predicts the distance available. I wasn't too worried because I was just a few kilometers from my destination. But afterwards I noticed it affected the battery balance. It took almost two weeks for the standard mode range to return to normal. That said there appeared to be no lasting effect.
    Roadster #919, Model S #2006
    Moderator: Tesla Motors , Electric Vehicles, EVents, Media
    , and Canada sub-forums.
    To the media: If you want to quote me, please contact me directly. I'll be happy to talk with you. Taking random postings out of context is not appreciated. Thanks!
  5. #15
    Member wiztecy's Avatar
    Apr 2012
    Santa Cruz
    Good information Doug, I also read from a Tesla note in this forum as well was to fully charge in standard couple of times to get the battery back into balance:
    "Just remember that the car does benefit from being allowed to sit fully charged in Standard mode, and should be allowed to do so frequently, especially if being used on a daily basis. Leaving the car plugged in in Standard mode after it is done charging will initiate this balancing program automatically. This doesn’t take much time, 30 minutes or so should do. It may take several of these balancing cycles to bring the car back to a balanced state if it has become imbalanced, which is something that a lack of regular Standard mode top ups and subsequent balancing cycles can induce."
    Tesla Roadster Battery Care
  1. Available kWh in Standard and Range Mode for Model S?
    By Wattson in forum Model S: Battery & Charging
    Last Post: 02-10-2013, 07:06 AM
  2. Range with standard charge mode in Model S
    By pguerra in forum Model S: Battery & Charging
    Last Post: 09-17-2012, 10:26 AM
  3. Standard mode: Ideal range?
    By James in forum Roadster
    Last Post: 04-05-2012, 12:11 PM
  4. Replies: 38
    Last Post: 07-30-2011, 08:36 AM
  5. Charge in Range; Drive in Standard?
    By smorgasbord in forum Roadster
    Last Post: 06-16-2011, 02:08 AM
