I like the idea of educating local officials. Why do you call it "The Amsterdam Model" are there articles about this online?
There is a builder that builds/remodels a lot in Culver City that uses a GEM to run around town. His first name is Bob and I may be able to find out his last name if you cannot locate him.
Obviously he deals with the building department on a regular basis and has an interest in electric, so he may be helpful in dealing with a department which has a tough reputation.
Get one of these: sidewalksleever
Even if you got the street side charging, I think it's a bad idea because like you mentioned the charge port is on the driver's side. Find a way to get the car in your garage or on your property.
My solution for charging my Chevy Volt was along the lines several others have suggested. I live in a townhouse with no garage, so I have to park and charge outside. My electrician ran a line from the front of my townhouse, under the sidewalk and placed the outlet in the narrow grass strip similar to what you have. Only difference it that I park head in and the charger on the Volt is driver's side front fender. When I get my S I'll have the electrician upgrade the plug and wiring and I'll back the S into the space to charge. Based on your various posts I don't see any reason you couldn't do something similar. I didn't ask anyone's permission, including my homeowners association and I haven't had any problems. In your situation with a similar kind of setup you'd have to parallel park with the driver's side along the curb.
Here are photos of my set up. The EVSE mounts on the green post when charging but the whole assembly is quickly dismounted and put away when not charging. With the Astroturf covered plug for the post hole, the installation is stealth when not set up to charge the car. As the S does not require an EVSE, all I need to do is plug into the outlet. But as I'll be getting twin chargers, I'll design a new stand to hold the High Power Wall Connector.
Neat solution artsci, but that plug location looks like an extreme shock hazard in damp/wet conditions unless GFCI protected - and if it is, subject to very frequent GFCI faults in wet weather... Water will collect in your outlet when it rains unless it has some provision for drainage! (Never mind the extension laying in the grass.)
Not an issue. Water has collected in the outlet during downpours and in fact completely covers it. I plug the extension in and out during these conditions. No sparks, no shocks, no GFCI faults, no other issues. I don't know what the electrician actually did, but his specialty is outdoor installations of this kind. He clearly knows his stuff. For what appear to be an unnecessary extra measure of safety (but piece of mind), during adverse weather conditions I wear electrician's rubber gloves when plugging in.
My electrician is coming in on Friday to upgrade my curbside install for the S. The wiring he's already put down can handle a 50 amp load but he has to upgrade the breaker. He also needs to upgrade the outlet to a NEMA 14-50. I've already found a NEMA 14-50 to L6-20 adapter so once the upgrade is complete the outlet will work for both the Volt and the Tesla S.
Saw this and it confirms that one day, there may be hope for my situation.
http://gigaom.com/cleantech/introduc...y-pole-mashup/
