Page 3 of 9 FirstFirst 1234567 ... LastLast
Results 21 to 30 of 85
Thread: UoCS Study: How Green are Electric Cars?
  1. #21
    2011 Nissan LEAF
    Jun 2009
    Encinitas, CA
    Quote Originally Posted by JRP3 View Post
    The full report, which should include their methodolgy, is supposed to be out today I think.
    It's here:
    Global Warming Emissions and Fuel-Cost Savings of Electric Cars (2012) | Union of Concerned Scientists
    Full report at the bottom of the page.
  2. #22
    Roadster 919, S 2006 Doug_G's Avatar
    Apr 2010
    Ottawa, Canada
    Blog Entries
    Quote Originally Posted by drees View Post
    There was no attempt whatsoever that I can see, with a quick perusal, to address well-to-wheels for ICE cars.
  3. #23
    2011 Nissan LEAF
    Jun 2009
    Encinitas, CA
    Quote Originally Posted by Doug_G View Post
    Haven't found the calculation, yet, but see page 8 of the full report where they say that they do. The Technical Appendix goes into great detail on how they calculated it for electric vehicles.
    Edit: They use 11,200 grams CO2 / gallon of gasoline which they took from GREET. The actual burning of a gallon of gas will result in 8,170 grams CO2.
  4. #24
    #1291 hjr's Avatar
    May 2011
    New Haven, Connecticut
    Why do the critics always use the Leaf or Volt as examples. The Leaf they say takes 0.34 kwh/mile. Today onthe highway in my Roadster 2.5 Sport I used 0.24 kwh/mile. In Connecticut they said the Leaf gets equivalent of 67 mpg, but if you use the actual numbers i get on my roadster it is more like the equivalent of a 95 mpg car.
  5. #25
    Nov 2010
    Minneapolis, MN
    It's pretty easy to do a thought-experiment comparison of electric to ICE. Make the assumption that coal, the dirtiest source of energy for electricity, causes as much CO2 creation in the mining and shipping process to get it to the power plant as oil causes from the drilling and pumping at the well to shipping/pumping it to the refinery. Then, take the energy alone used to refine it into gasoline at 5-7kWH and stick that energy directly into my Roadster. I've just saved 19 lbs of CO2 from being created by not burning that gasoline, and I can now drive 20 miles using the 5kWH, the same distance a performance-comparable Porsche 911 Turbo could have driven on that gallon of gas (on average... they're 16 city, 24 highway). If they argue that the transmission line losses make up the difference, remind them that we didn't have to truck that gasoline from the refinery to the gas station, and it didn't have to evaporate as it was being pumped into the ICE car.
    It's a simple explanation, and it proves our point definitively.
  6. #26
    Senior Member JRP3's Avatar
    Aug 2007
    Central New York
    Quote Originally Posted by hjr View Post
    I think it's reasonable to use currently available vehicles that most people might actually buy. The Roadster doesn't really count.
  7. #27
    Member DuncanWatson's Avatar
    Apr 2012
    Seattle, WA
    I went through the Prepublication paper as well and though found references to well to wheel, I couldn't see anywhere were the cost was calculated for an ICE vehicle. It calculated the cost of EV to a miles per gallon of green house gas equivelant. No reference to what one gallon of ghg is equal to or what assumptions upstream it makes on the production of a gallon of gasoline.
    This means that the work is unverifiable.
  8. #28
    Aug 2007
    Central New York
    Quote Originally Posted by DuncanWatson View Post
    According to Drees they used the GREET model, which includes upstream emissions for gasoline.
  9. #29
    ERIC VFX vfx's Avatar
    Aug 2006
    Not without mentioning the capabilities of the Roadster and how that it is entirely reasonable to assume that all EVs will get better with each year and the Roadster is proof.
    This kind of report if widely accepted will stop time.
    Just like people are stuck on old info and data like "you have to drain the battery" and " the heater and headlight kill range" and memes from the 90's.
    At least it kills the "electric cars are dirtier because they run on coal" line that was probably more true 20 years ago.
  10. #30
    Aug 2007
    Central New York
    Unless most EV's are going to be small sports cars their efficiency is probably not going to be similar to the Roadster. There is also the issue of charging efficiency, the Roadster seems to use a lot more energy managing the pack than other EV's, which lowers it's actual wall to wheels efficiency.
  1. Do green leaders drive electric cars?
    By vfx in forum Electric Vehicles
    Last Post: 05-31-2012, 07:33 PM
  2. Is It Just Another Fade? Green Cars, Smart Cars etc...
    By XtremeCarsandStars in forum Cars and Transportation
    Last Post: 01-27-2007, 03:45 PM
  3. Is It Just Another Fade? Green Cars, Smart Cars etc...
    By XtremeCarsandStars in forum Tesla Motors
  4. Replies: 0
    Last Post: 10-25-2006, 06:30 AM
  5. Battle of the Green Cars!
    By tonybelding in forum Roadster
    Last Post: 09-02-2006, 04:43 PM
