Page 20 of 20 FirstFirst ... 101617181920
Results 191 to 194 of 194
Thread: Marginal power
  1. #191
    Model S Sig Perf, VIN 586
    Apr 2012
    Rocklin, CA
    Quote Originally Posted by JRP3 View Post
    10 gallons of gas at 33kwh equivalent per gallon is 330kwh. The entire petroleum chain from well to tank is about 80% efficient, so that means 20% is used to produce the final product, so the 10 gallons took 66kwh of energy, (not electricity). Now don't forget that the 85kwh's of electricity in a battery pack started out as a lot more energy than that using a generous 40% generating efficiency, (marginal power is probably lower), plus 93% transmission efficiency, a generous 90% charging efficiency, and not to mention the drilling/mining energy inputs, which I don't have the figures for. You have to apply equal criteria for all inputs when comparing gas to electricity.
    I've figured out what bothers me most about these figures: 33kwh equivalent per gallon.
    How did that number get figured? I know of no way to convert 1 gallon of gasoline to 33kwh of electricity. There are enormous losses involved in any conversion of gasoline to electricity so the number must be something like the amount of work a gallon of gas can do ... like power a car. If that's the way the equivalency is developed then no wonder all the math ends up with them equivalent. You come up with a more efficient car than the average car the equivalency was developed on and bingo, the more efficient car is more efficient.
  2. #192
    TSLA will win Norbert's Avatar
    Oct 2009
    San Francisco, CA
    Quote Originally Posted by Jason S View Post
    The number is 33.7 kWh (EPA), and while I don't know exactly how it is measured or calculated, I expect it to correlate to the amount of heat (=energy) you get when you burn gasoline as completely as possible. Most of the inefficiency in a car is lost as heat (and friction, which also becomes heat).
    Buying an EV is one thing, being able to drive it beyond city limits another...
  3. #193
    33.7kWh represents the energy contained in a gallon of gas (as specified by the EPA: http://www.fueleconomy.gov/feg/evsbs.shtml). It would be what you would get if you were able to convert a gallon of gas to electricity at 100%. You will see slightly different numbers (energy in a gallon of gas varies with temperature, pressure and the specific mix you get), but in general that number is correct.
    To figure that number out you use something like a calorimeter:
    http://en.wikipedia.org/wiki/Calorimeter
    Gasoline refining efficiency is 89.7% (including all products), 86.2% (excluding less desire-able products). So what JRP3 says in general is correct (can't assume energy used to refine a gallon of gas can be used to power an EV for the same miles).
    http://www.transportation.anl.gov/pdfs/TA/635.PDF
    In general for such energy comparisons, the GREET model is the best resource (uses unbiased methods and examines the entire fuel chain):
    http://greet.es.anl.gov/
    Because there are tons of crazy people in this world...
  4. #194
    Senior Member JRP3's Avatar
    Aug 2007
    Central New York
    Right, we aren't looking to actually turn the gallon of gasoline into electricity, just using the potential energy value to calculate production losses.
  1. How much power from 12 V power outlet?
    By linaser in forum Model S: Battery & Charging
    Last Post: 02-22-2013, 06:40 PM
  2. Replies: 1
    Last Post: 12-13-2011, 08:38 PM
  3. Replies: 2
    Last Post: 08-19-2011, 10:43 AM
  4. Power of D.C.
    By doug in forum News
    Last Post: 09-20-2009, 07:11 PM
  5. MORE POWER
    By feelthesweetbeat in forum Roadster
    Last Post: 06-23-2007, 02:41 PM
