Page 4 of 4 FirstFirst 1234
Results 31 to 38 of 38
Thread: Potential battery pack upgrade for Roadster using Model S cells
  1. #31
    Senior Member WarpedOne's Avatar
    Aug 2006
    Slovenia, Europe
    That should be exciting. Given the Model S uses 3100mah vs the 2400mah cells in the Roadster, they can either:
    1) Keep the same number of cells and get 1.29x the capacity (72kWh) and power (only useful if they upgrade the firmware/motor/power electronics to use it).
    2) Keep the same capacity and use less cells, shaving 22.6% the cell weight (~150lbs) and volume (plus whatever overhead).
    No, they can and I am sure they will do some of BOTH i.e. reduce the number of cells for about 10% and still make a pack with a bit higher capacity, power and lower weight. It will have better acceleration, lower average power (less prone to overheating) and better range at lower price than full option 1.
    Don't tell me what you think and know, tell me what you see.
  2. #32
    Sig 100 - #52 frequencydip's Avatar
    Dec 2011
    Los Angeles
    Quote Originally Posted by WarpedOne View Post
    I really don't think they are going to produce multiple battery upgrade options. there are 2400 cars and only a small portion will need an upgrade in the next few years, the R&D in one updated pack will already be allot. I'm sure they will again redesign the packs in another 5-10 years with the latest cell tech available. The thing that is unique about the Roadster and hopefully Tesla is the idea of these cars are not disposable, and that they can go on forever. When many of our car interiors are shot I'm sure they will offer a seat upgrade, a dash board upgrade etc. The Roadster is a much simpler car when it comes to parts it so easy to replace anything except the frame.
    My personal hopes for a battery upgrade is a little bit of everything, but in the following order.
    1) less weight
    2) more acceleration
    3) more range
    The less weight is really important, it effects everything else; acceleration, handeling, range, tire wear, stopping distance etc. Dropping 150lb is huge, I can really feel the difference of the cars abilities when I have a passenger in the car, imaging that difference when basically dropping the weight of the driver...
  3. #33
    Senior Member hcsharp's Avatar
    Jun 2011
    Vermont
    Quote Originally Posted by smorgasbord View Post
    I wish Tesla would wait another couple of years, so that battery technology can improve even more. Right now there aren't many Roadsters that need new packs.
    I would hope that Tesla would have two options:
    1) More Range, same pack size/weight
    2) Same Range, less weight and that weight set as low as possible in the car.
    I agree with the option choices. It probably wouldn't be much work to offer it for a lot of money now to those who want it. That won't prevent them from improving it continuously so when the rest of us are ready in a few years, it will be even better and cheaper.
    Quote Originally Posted by Kevin Sharpe View Post
    Sorry but I disagree... I want Tesla to give us lots options... some wealthy early adopters will buy on day one and others will buy later.
    Just curious Kevin, what would be a reasonable price to pay for a 17kw 3-ph charging upgrade on the Roadster?
  4. #34
    Senior Member
    Jul 2010
    Bradford on Avon, UK
    Quote Originally Posted by hcsharp View Post
    On it's own I'd probably pay $5k. However, combine it with a significant range increase then I'd pay a lot more.
    Dream scenario would be 43k 3 Phase and 320+ miles because I could then drive anywhere in Europe.
  5. #35
    #421 Model S #S32 Eberhard's Avatar
    Oct 2010
    Germany
    I fully agree with you Kevin. Even 22kW 3 Phase would be fine or DC charging like Model S (or both) then the current range would be sufficient.
    Roadster EU#421 162.900km MS Sig P85+ 148.000km
  6. #36
    Senior Member Raffy.Roma's Avatar
    Jul 2012
    Rome (Italy)
    I would prefer option 1. But what would happen if somebody gets the second battery replacement option now and then a new battery for Roadster based on Model S cells would come out? Would he get automatically the new battery or should he pay extra money to get it?
  7. #37
    Roadster F#25 pharma5's Avatar
    Nov 2011
    central NJ
    Quote Originally Posted by frequencydip View Post
    I am definitely in that boat: http://www.teslamotorsclub.com/showt...s-Future/page4
    If there is a macro upgrade in the works, I am very curious about the possibility of designing in supercharging capability, perhaps at same nominal range with other improvements mentioned on this thread (lower weight via fewer & newer cells, better cooling, effectively better performance...). Would also give faster recharge option (!) + effective range via supercharge network.
    All that rolled up with a fresh "powertrain" warranty might snag a nice price tag. But what would it take - a fresh look at ESS, PEM, and motor?
    If it's a straight pack upgrade, I vote for max range (e.g., same number of the newest cells). And HPCs at the supercharger sites.
  8. #38
    Senior Member smorgasbord's Avatar
    Jun 2011
    SF Bay Area
    With so few cars on the road, I want Tesla to choose carefully what they do. Doing battery upgrade now means just a minor improvement, whereas waiting for Gen-III type batteries should bring cost down and capacity up and, maybe most important of all, reduce the center of gravity so that car handles more like a real Lotus. It's not just the weight, it's the distribution of weight, and in Roadster some of the battery pack is up pretty high.
    Water cooled PEM and motor is, of course, something that would be a really big benefit, and I would assume that engineering work could be done now. I recommend that, plus a brake upgrade and then a few years down the road take on the battery.
  1. Replies: 12
    Last Post: 2015-08-15, 11:20 PM
  2. Replies: 256
    Last Post: 2014-05-31, 07:09 PM
  3. Model S Battery Pack Charging Protocols
    By gkalexdc in forum Charging Standards and Infrastructure
    Last Post: 2012-07-12, 04:33 PM
  4. Roadster battery pack specs?
    By iisjsmith in forum Roadster: Technical
    Last Post: 2007-06-24, 09:00 PM
  5. Roadster battery pack specs?
