Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Power your home from the battery
  1. #11
    Senior Member Lloyd's Avatar
    Jan 2011
    San Luis Obispo, CA
    Interesting! Thanks for setting me straight!!
    SP-2823 XP-12
  2. #12
    Senior Member
    Aug 2011
    Raleigh, NC
    I like the "emergency" case. I'd love to be able to just turn this feature on when my power goes out.
  3. #13
    Jul 2008
    Angwin (Napa Valley) CA
    If you already have PV, or are planning to get PV panels, the cost to go to an emergency off grid situation for a day or two is not nearly as expensive as buying an electric car: Lead acid batteries, large and heavy, are cheap by comparison to the light, small batteries required for automotive use. I have a couple thousand dollars in sealed glass mat lead acids that are supposed to last ~20 years with absolutely no maintenance other than the charging supplied by panels. In case of grid failure, the batteries kick in, in 1/300th of a second with computer grade sine wave. A gas fired generator would cost more than the battery system upgrade.
    My house uses about 17 kWhk, the water pump and septic pump use about another equal, and the electric car uses another similar (YMMV)
  4. #14
    Administrator dpeilow's Avatar
    May 2008
    Winchester, UK
    Quote Originally Posted by dsm363 View Post
    You're right. Found this
    How much electricity does an American home use? - FAQ - U.S. Energy Information Administration (EIA)
    Looks like the average is closer to 30 kWh/day.
    UK average is 10 - 11.5 kWh depending on which study you take.
    What the hell are you guys running? Aluminum smelters?
  5. #15
    Roadster 919, S 2006 Doug_G's Avatar
    Apr 2010
    Ottawa, Canada
    Blog Entries
    Quote Originally Posted by dpeilow View Post
    I would suspect air conditioners. Also houses in the southern USA have crappy insulation, which doesn't help with A/C.
  6. #16
    Senior Member jcstp's Avatar
    Feb 2011
    Belgium
    one way to get off the grid and live of batteries
  7. #17
    ERIC VFX vfx's Avatar
    Aug 2006
    GM Turns Used Volt Batteries Into Off-Grid Power Structure - Earth911.com
    The ABB Group's off-grid structure uses five former Volt batteries to provide 25 kilowatts of power, or enough energy to power three to five average American homes for two hours.
  8. #18
    Quote Originally Posted by Doug_G View Post
    Tesla has stated that this will not be supported by the Model S.
    Not only "not supported," but will void the Model S warranty.
    2013 Model S Performance
    VIN 5348, Delivered 3/9/13
    Pearl White, Black, Pano, 21" Silver, Carbon, Tech, Sound, Twin Chargers
  1. Replies: 15
    Last Post: 06-11-2012, 01:07 PM
  2. Replies: 1
    Last Post: 12-13-2011, 08:38 PM
  3. Obama pushes electric cars, battery power this week
    By TEG in forum Electric Vehicles
    Last Post: 07-14-2010, 08:45 AM
  4. Charging car battery on the move with wind power
    By Retellect in forum Technical
    Last Post: 12-15-2009, 09:15 PM
  5. Replies: 3
    Last Post: 10-18-2009, 01:31 PM
