Page 5 of 5 FirstFirst 12345
Results 41 to 49 of 49
Thread: DIY RC Model S
  1. #41
    I added a couple of pictures above, you can see some of the 'metal shop' the laser welder and jewelry bench is on the one side you cant see from the pics.
    I messed around with some titanium and aluminum earlier. i think I will probably use titanium and stainless steel mostly for the frame of my next S RC. We'll see, still designing it
  2. #42
    Quote Originally Posted by Zextraterrestrial View Post
    No one has offered anything but I am starting to make one from scratch.
    I realize you're early in the process, but assuming it's < $100 ... Are you taking reservations? If so, sign me up.
    If it's more than $100, I might still be interested but I'd like more details and a ballpark price.
    Feel free to continue the discussion in PM if you'd prefer.
    Thanks!
  3. #43
    < $100 just for the receiver and transmitter. I am looking at a $60-70 motor and ESC set that will probably make the new one do 25-50mph (gearing?) and smoke the tires!
    I'm not sure how much time the first frame will take to build. My design has the weight ratio's exactly the same as the S and CG in the same spot. I might have to play around with battery position F/R to get it perfect but It should be fairly 'easy'. Batteries will be ~$20, Steering servo $10-20, titanium & SS- cheapish. Miscellaneous pre-made parts - not sure what I am going to fabricate yet.
    I made it to TAP and picked up some 30mil polycarbonate. Much better for small vacuum forming. I ran a quick test this morning (before pk power hrs ; >
    but didn't dry the poly again - so the air bubbles are still present. This stuff is much lighter and will really help keep the CG low
    worked much better. I think it will be good once I heat the PC fully and pre-dry it
    last side of the jewelry shop area - laser on the left, mmm, technology is pretty cool!
  4. #44
    < $100 just for the receiver and transmitter. I am looking at a $60-70 motor and ESC set .... Batteries will be ~$20, Steering servo $10-20, titanium & SS- cheapish. Miscellaneous pre-made parts - not sure what I am going to fabricate yet.
    Sounds like around $200-$250 + labor?
  5. #45
    sounds a little low... my small Rc heli was ~$650. I'd guess more like $500 total (including cheap labor) tires run maybe $10 a pair, wheels $20. I'll probably source suspension parts from something else as well as a rear end differential. Random wiring and some lights. charge port magnets and connector It will be more than I should be spending on it
    If anyone is interested in a logo 500se I might be into selling the big one (German made)
  6. #46
    Ok, cool. Just looking for a ballpark to calibrate against budget.
    Let me/us know if/when you are taking reservations or whatever.
  7. #47
    Any updates, Z? I'm curious how it's progressing as I wait impatiently for my larger version.
    Truly Electric Spaceship-Like Adventure ~ Signature Model Spaceship
    PLEASE NOTE: these musings are the copyrighted intellectual property of the author, and are intended as part of a conversation among the Tesla Motors Clubs membership. My words may not be quoted by any third party outside the Tesla Motors Clubs forums, without my expressed consent. Especially the NYT, which is clearly ethically challenged.
  8. #48
    Waiting for the GENIII gjunky's Avatar
    Mar 2012
    Scottsdale, AZ
    Perhaps you can put it on Kickstarter.com
    I am sure you will have it funded it no time.
  9. #49
    Wot? No self-levelling air suspension? Clearly not realistic.
  1. DIY Home EVSE
    By vfx in forum Charging Standards and Infrastructure
    Last Post: 01-28-2013, 07:47 AM
  2. 1974 diy ev
    By Adm in forum Electric Vehicles
    Last Post: 08-23-2012, 09:21 PM
  3. DIY RC Model S
    By Zextraterrestrial in forum Model S
    Last Post: 06-07-2012, 08:29 AM
  4. DIY BMW beats Roadster
    By JRP3 in forum Video
    Last Post: 10-16-2011, 09:35 AM
  5. DIY Charging Networks
    By malcolm in forum Technical
    Last Post: 05-28-2009, 09:02 AM
