Page 28 of 58 FirstFirst ... 1824252627282930313238 ... LastLast
Results 271 to 280 of 575
Thread: Open Vehicle Monitoring System
  1. #271
    Senior Member markwj's Avatar
    Apr 2011
    Hong Kong
    Interesting discussion regarding PIN. I'll raise it on the ovmsdev list.
    PLEASE NOTE:
    These musings are the copyrighted intellectual property of the author, and are intended as part of a conversation among the Tesla Motors Clubs membership.
    My words may not be quoted by any third party outside the Tesla Motors Clubs forums, without my express consent.
  2. #272
    Apr 2011
    Hong Kong
    Quote Originally Posted by jcstp View Post
    The new Rav4 EV has a Tesla drivetrain! Maybe OVMS will work with it with no problem!
    Depends more on the car VMS more than the drivetrain.
    Volt/Ampera should come next. Leaf is not too hard if someone has an itch.
    PLEASE NOTE:
  3. #273
    R #1211, SSL#282, XS#313 NigelM's Avatar
    Apr 2011
    Sarasota, FL
    Quote Originally Posted by markwj View Post
    It appears (we can only guess from looking at CAN bus messages) that the VDS tells the VMS what it is interested in, and from that point on the VMS broadcasts the interested messages on the can bus. So, calling up the temperature screen on the VDS makes the VMS start transmitting temperature messages. If you never call up that screen, the messages are never sent. You fixed it yourself
    How long does the VMS keep sending? Indefinitely, from what I can tell. there must be some 'deep sleep' event that would cause it to stop, but mine is certainly being sent and it has been months since I called up that screen.
    I lost the powertrain temps yesterday after a service call. I had obviously disconnected the OVMS module prior to the Ranger's arrival. He fitted new fans, replaced a faulty headlight and reinstalled the latest firmware. One of those made the VMS go into the "deep sleep" you mentioned. My module is reconnected and I'm going to run through the PEM screens right now.
  4. #274
    Apr 2011
    Hong Kong
    Quote Originally Posted by NigelM View Post
    For fun, call up the temperatures on OVMS. Then switch the VDS car screen to temperatures. You should see the iPhone update immediately.
    PLEASE NOTE:
  5. #275
    Apr 2011
    Sarasota, FL
    Took maybe 10-12 seconds.....
  6. #276
    #1291 hjr's Avatar
    May 2011
    New Haven, Connecticut
    I set the OVMS to be able to write to the CAN today. It worked perfectly with lock, unlock, and charge functions. Only bug seems to be that the car locks itself now during charging. It never did that before I installed the OVMS while charging. Is this normal? I am a bit worried about this since I almost never take my keys out of the car when at home or the office. I worry the OVMS might self lock and use a password I cannot access.
  7. #277
    Apr 2011
    Hong Kong
    Quote Originally Posted by hjr View Post
    ??? Huh ???
    Absolutely not normal.
    The way the lock works is OVMS sends a can bus message containing the car"s lock/unlock pin. The car validates the pin and locks if correct. If the pin is incorrect, the car refuses to lock.
    We don't store that pin anywhere. Not in the App, not in the Server, not in the car module. And, the only code path leading to the lock message being sent is an app sending a lock/unlock message to the connected car via the server. The server will only forward this message to a connected car - it cannot store and forward the message later.
    The other thing to point out is that US and non-US cars behave differently. For US cars, can bus lock/unlock messages affect the car doors and alarm. Non-US cars are fitted with an immobiliser, which can bus lock/unlock cannot affect - so OVMS can lock/unlock the doors but cannot arm/disarm the alarm or immobiliser.
    For your case, I would like to check the server logs. What is your vehicle ID, and what time (and timezone) did you start the charge?
    PLEASE NOTE:
  8. #278
    Junior Member Quasimodo's Avatar
    Feb 2012
    Copenhagen
    [*]Notification of charge completion/interruption and other ancillary messages is available via SMS and/or Android/Apple PUSH notification.
    Hi Mark
    Still very happy with the OVMS in my Roadster.
    Thought you probably considered enabling the user to have an alarm to go off whenever charging is prematurely terminated - in addition to the current notification.
    Sound asleep in a hotel bed, I would like to have an alarm wake me up if charging is prematurely terminated - as it might prevent me from moving on as planned the following morning.
    Is such a feature anywhere high up on your dev/priority list ?
    /Q
  9. #279
    Senior Member W.Petefish's Avatar
    Apr 2011
    North Texas (DFW)
    It has been implemented. The module sends you notifications when the charge stops.
    If it is worth doing, it is worth OVER doing. - Mythbusters
    Debunking Pseudoscience is fun!
    Arctic White Roadster 2.5 #1200, S Sig Performance Vin# 227
  10. #280
    Apr 2011
    Hong Kong
    Quote Originally Posted by Quasimodo View Post
    For the push notifications, we use the 'default' sound with Apple. You set that in Settings/General/Sounds. But, also make sure Settings/Notifications/OpenVehicle has sounds on.
    There's no way with Apple to have an alarm clock load up. We can customize the sound, but it is messy.
    If you really want something loud, the SMS notifications on iPhone have more granularity. You can configure a custom ringtone on the contact that is your car.
    Regards, Mark
    PLEASE NOTE:
  1. Open Vehicle Monitor System (OVMS) - Technical Discussion
    By markwj in forum Technical Discussion
    Last Post: 04-16-2013, 07:55 AM
  2. Tire pressure monitoring
    By Alan in forum Technical Discussion
    Last Post: 09-06-2012, 07:18 PM
  3. Replies: 19
    Last Post: 03-31-2012, 05:05 PM
  4. Replies: 0
    Last Post: 10-22-2011, 05:23 AM
  5. Vehicle Display System (VDS) touchscreen
    By doug in forum Technical Discussion
    Last Post: 06-12-2011, 10:45 PM
