It definitely shuts off on my car. Yours may be different. Here's what happens: You brake and slow to 1-2 mph when it transitions from regen to creep. You keep applying brakes but more lightly in hopes of coming to a smooth stop. Meanwhile creep is still on so the brakes are applied more than they need to be if you had no creep. Then suddenly just before final stop, creep shuts off and you come to a jerky stop because your brakes are still applied hard enough to overcome creep, but creep is now off. If you keep your foot on the brake while stopped, creep will stay off. Cinergi described it in post 28 and you can observe the amps drop when fully stopped and creep is off. If they kept creep on a second longer you could stop smoother, but still not perfect.
One solution to the jerky stop would be to transition the creep off a little slower so you could adjust brake pressure accordingly and stop smoothly. Not sure why they don't do that. There may be a minimum amount of power they have to send the motor due to a minimum duty cycle of the PWM electronics, preventing a smoother shut-down of power. Maybe they tried other methods of shutting down creep and it created other problems... So many times I wish I could interview the engineers who worked on this or that.
